Submersible discovering a lost U Boat
  • Peter Gillson
    • 2594
    Hi guys
    Taking a rest from figures, in particular my Dunkirk series and its time to start this one:
    The plan is to make a boxed diorama featuring a wrecked submarine, being discovered by a remote submersible vehicle which will have a led fitted. Hopefully the inside of the boxed diorama will be reasonably dark (like the deep ocean) with the led illuminating it.
    it looks a very straightforward kit - here are the sprues:
    the hull - a sox inch ruler gives an idea of the size.
  • Peter Gillson
    • 2594
    The first stage will be to build a wrecked U Boat.
    being a believer in the learn-from-other-people principle I am going to follow the way Ron built his, larger, wrecked U Boat as per his blog:
    step on is to mark out the hull and take my trusty Dremel to it, so it off to the workshop to do this.
    • Peter Gillson
      • 2594
      After an hour in the workshop, dremel in hand I have produced this:
      at first I drilled through but the plastic is quite thick and the holes looked too false so I changed the tool to a larger grit-block type of thing and from the inside thinned the plastic in the areas where the holes would be until it was very thin - or until I was right through, as in a couple of places! Then I changes to a smaller bit and carved out the holes.
      the fortunate thing about a boxed diorama is that I only have to really detail one side!
      • Mickc1440
        • 4775
        Been looking forward to this project starting, nice start on the erosion
        • Waspie
          • Mar 2023
          • 3488
          • Doug
          • Fraggle Rock
          Peter, are you going to show the inner pressure hull through the outer hull damage?
          Looking forward to this one progressing. Interesting subject. :thumb2:
          • Mini Me
            • Jun 2018
            • 10711
            So Peter, I thought this was going to be a German U boat not a "Swiss" one! :tears-of-joy: :tears-of-joy: That hull is riddled to say the least. But I know you have a plan for this, so I'll stay tuned for further developments.:thumb2:
              • 15692
              Sounds a very interesting build. Will there be any interior details at all visible through the holes or are you just going to rely on dark and murky?
              • Peter Gillson
                • 2594
                Mick - welcome aboard, I hope the result is worth your anticipation.
                Doug - yep, a representation of the pressure hull is inserted.
                Rick - I have a plan, but as one general (I cannot remember who), said - no plan survives the first contact with the enemy! Let's see how this develops!
                Jim - in this scale I think dark and murky will do. I admit that I was tempted to but one with interior
                details but decided that would make the project far to big and time consuming.
                here is a photo of the assembled sub:
                it is a simple build and went together quite well - although since it will be covered any slight misfitting did not matter. Now for the white glue and barnicles, and for those i'm off to raid the kitchen.
                i'm not sure whether or not I will use all of the sub, that decision will be made when I start to make the box, so the whole thing will be covered.
                Peter
                • Waspie
                  • Mar 2023
                  • 3488
                  • Doug
                  • Fraggle Rock
                  The bow damage, vertical lines, makes it look like it did battle with the screws of a large surface vessel and lost!!!!
                  Just read a book by a chap called David Black about similar damage to one of our subs in WW2.
                  • Peter Gillson
                    • 2594
                    Doug - i just attacked it, no real thought as to how the damage would have been caused.
                    • Mini Me
                      • Jun 2018
                      • 10711
                      A few well placed Depth Charges would have been my guess :thumb2:
                        • 22770
                        Great idea, and a great start Peter. Just pulled up my chair for this one, I will sit quietly at the back.
                        • Peter Gillson
                          • 2594
                          Hi Guys
                          a box of polenta and semolina later and we have this:
                          After adding some colour - various shades of brown with touches of yellow or green with a few places where there is a hint of red. Since the aft area will be in the deepest shande it has the darker blueish shades.
                          a the moment I think the colours are unrealistic for the deep sea - as tou get deepet the colours go leaving everything blueish grey. It is surprising how quickly colour vanishes, I recall my diving days and even at 35 mtrs it is mostly grey. I think I will need to make the rear - the part which will be least illuminated by the remote vehicle - darker to help emphasis the light and the general darkness.
                          while the paint dries, I can play with the LEDs.
                          • Peter Gillson
                            • 2594
                            i have a couple of LEDs, a white one and a blue one and to evaluate them I decided to try illuminating my Ambush boxed diorama since it is quite dark - here are the results:
ID:	1207113Click image for larger version
                            I think the blue might be a bit too blue so I am planning on using the white, which will mean making the aft of the sub a lot bluer. It is now a bit of wait and see' - until I build the box I will not know how dark to make the aft section.
                            so, next is back to woodworking.
                            Peter
                            • JR
                              • May 2015
                              • 18273
                              Great idea Peter , looking fwd to the box.
                              Nice table top in that photo, liked the burr.
