Brian's 1/48 Dkm u-Boat Type Viic U-552
  • Bri62
    • Jan 2023
    • 1883
    • Brian
    • Widnes Cheshire
    #136
    Had a couple of hours in the model room but most of it was waiting for stuff to dry.
ID:	1217488Click image for larger version
ID:	1217489Click image for larger version
ID:	1217490Click image for larger version
ID:	1217491Click image for larger version
    • Waspie
      • Mar 2023
      • 3488
      • Doug
      • Fraggle Rock
      #137
      Nice steady progress Brian. Love getting the updates.
      Seeing your builds Brian has made me realise what an untidy builder I am, (have become). I do try and organise myself and be tidy minded but it last about ten seconds!!!!!
      • langy71
        • 1950
        • Chris
        • Nottingham
        #138
        You and me both mate,
        Brian should be an honorary member of the 'Tidy Bench Club'... :thumb2:
        • Bri62
          • Jan 2023
          • 1883
          • Brian
          • Widnes Cheshire
          #139
          I'll be finished this module today.
ID:	1217554Click image for larger version
ID:	1217555Click image for larger version
ID:	1217556Click image for larger version
ID:	1217557Click image for larger version
          • Bri62
            • Jan 2023
            • 1883
            • Brian
            • Widnes Cheshire
            #140
            Hi just finished that module, just going to put the lights in the control room and aft living space later tonight all being well.
ID:	1217582Click image for larger version
ID:	1217583Click image for larger version
ID:	1217584Click image for larger version
ID:	1217585Click image for larger version
ID:	1217586Click image for larger version
ID:	1217587Click image for larger version
              • 18271
              Sure is a lot of details in those compartments. Excellent work too Brian.
              • Bri62
                • Jan 2023
                • 1883
                • Brian
                • Widnes Cheshire
                #142
                Ok done the wiring and I have decided I'm cr4p at soldering, Engine room next I'll be right at home :smiling3:
ID:	1217642Click image for larger version
ID:	1217643Click image for larger version
ID:	1217644Click image for larger version
ID:	1217645Click image for larger version
                I think the control room needs another light what do you think?
                • Mark1
                  • Apr 2021
                  • 4156
                  #143
                  Looking excellent Brian, think you may be right about the light
                  • boatman
                    • Nov 2018
                    • 14482
                    • christopher
                    • NORFOLK UK
                    #144
                    AN YES Bri another light def :thumb2: but lookin good matety
                    chrisb
                    • Waspie
                      • Mar 2023
                      • 3488
                      • Doug
                      • Fraggle Rock
                      #145
                      I think the control is fine Brian. Canโ€™t imagine they would want it too bright. Also, conserve light bulbs, they would be changing them frequently when under attack from DCโ€™s!!
                      • Bri62
                        • Jan 2023
                        • 1883
                        • Brian
                        • Widnes Cheshire
                        #146
                        There is actually 3 lights in the control room its just one is behind the attack periscope you can only see it at an angle.
                        • Waspie
                          • Mar 2023
                          • 3488
                          • Doug
                          • Fraggle Rock
                          #147
                          If you look at any operations room at sea and it'll be in almost total darkness with only the dim light from the consoles shedding light around. On a submarine, the only one who would have a dedicated light would be the navigation officer and then only over the nav plot table.
                          As an aside. even in ASW aircraft the non pilot end would be in darkness. In Sea Kings, we had blackout curtains against all the cabin windows, illumination was minimal.
                          • langy71
                            • 1950
                            • Chris
                            • Nottingham
                            #148
                            There aren't enough words to say how fabulous this is going, so I'll just say WOW !! for now, (and go read a thesaurus to learn some more).... :thumb2: :thumb2: :thumb2: :thumb2: :thumb2: :thumb2: :thumb2:
                            • Bri62
                              • Jan 2023
                              • 1883
                              • Brian
                              • Widnes Cheshire
                              #149
                              Been thinking ahead and am a bit concerned about drilling out the air vents on the clear acrylic side found some reports of it cracking. Anyone had any experience with acrylic?
                                • 18908
                                Acrylic is more brittle than polystyrene. Problems probably come from going in too fast and hard with the drill and not supporting the back of the part being drilled.
                                I would make sure the part is clearly Centre marked and properly supported at the back. Use a good sharp drill. Take it slowly without forcing the drill in, possibly drilling by hand rather than using a power drill. Finally, I would lubricate the drill site with something organic like candle grease.
