Brian's 1/48 Dkm u-Boat Type Viic U-552
  • Neil Merryweather
    • Dec 2018
    • 5182
    • London
    #151
    Acrylic is more brittle than polystyrene. Problems probably come from going in too fast and hard with the drill and not supporting the back of the part being drilled.
    I would make sure the part is clearly Centre marked and properly supported at the back. Use a good sharp drill. Take it slowly without forcing the drill in, possibly drilling by hand rather than using a power drill. Finally, I would lubricate the drill site with something organic like candle grease.
    I would also recommend drilling a smaller hole at first and then enlarging it gradually and gently
    • Bri62
      • Jan 2023
      • 1879
      • Brian
      • Widnes Cheshire
      #152
      Thx guys............. or I could paint them matt black as there recessed?
      Bit more done very fiddly stuff
ID:	1217737Click image for larger version
ID:	1217738Click image for larger version
        • 18890
        If I was going that way I’d use a five sided cutting broach Neil. They open out a hole without changing its position. You can very easily drift the hole out of alignment otherwise. A tapered needle file rotated in the hole will also work, just remember to turn it counterclockwise so it doesn’t pull itself inwards and jam or split the workpiece.
        • spanner570
          • 15383
          #154
          Brian, the air vents /water displacements slots have to be drilled out as you need to see daylight through the hull. Well worth doing.
          A bit of a ball ache to do. Especially in smaller scales I did.
          I drilled mine out with a small drill to start with and then filed them to the correct shape.
          • Bri62
            • Jan 2023
            • 1879
            • Brian
            • Widnes Cheshire
            #155
            Yes Ron not a problem doing them, just a bit worried about the acrylic cracking as some is staying clear a crack would be impossible to hide.
            Going to take quite a while to do as well
            • spanner570
              • 15383
              #156
              Yes indeed, not an easy task - and very repetitive.
              For this application on my 1/72 U. Boat, I used a heat source (An old, hot precision screwdriver) for the first 'Penetration' of the vents. Not for the faint hearted, but its safe and prevents any cracking of the acrylic. Then clean up with a suitable file.
              • Bri62
                • Jan 2023
                • 1879
                • Brian
                • Widnes Cheshire
                #157
                A little progress
                • scottie3158
                  • 14199
                  • Holbeach
                  #158
                  Brian,
                  I have just had a good catch up, and wow some great work going on mate. The illumination looks spot on to me.
                  • Bri62
                    • Jan 2023
                    • 1879
                    • Brian
                    • Widnes Cheshire
                    #159
                    Thanks Paul
                    • Neil Merryweather
                      • Dec 2018
                      • 5182
                      • London
                      #160
                      really enjoying this Bri
                      • Bri62
                        • Jan 2023
                        • 1879
                        • Brian
                        • Widnes Cheshire
                        #161
                        Thanks Neil, me too at the moment
                        • Airborne01
                          • Mar 2021
                          • 3947
                          • Steve
                          • Essex
                          #162
                          Neil took the words right out of my typing finger. Super work matey!
                          • Bri62
                            • Jan 2023
                            • 1879
                            • Brian
                            • Widnes Cheshire
                            #163
                            got my 3d stuff this morning from Poland, the more I think about it the more I'm thinking of getting one especially now as I have finished fishing due to my arthritic back and hips so will have plenty of time.
ID:	1217827Click image for larger version
ID:	1217829Click image for larger version
                            • Mark1
                              • Apr 2021
                              • 4156
                              #164
                              Looking good :thumb2: 3d printer does sound good but my greatest technological achievement was sussing out i could make a call on a rotary dial phone that had one of them locks on it by tapping out the number on the little button under the receiver lol
                              • Waspie
                                • Mar 2023
                                • 3488
                                • Doug
                                • Fraggle Rock
                                #165
                                Loving the boxes of victuals!!!! Most important stores next to weapons!!!
