hello Gentleman My name is Glenn and I'm based out of Norfolk Virginia and this is my first post,my subject is U-249 Late 1945,my problem is finding the right color, the photos I have shows her next to U-1023 and U-249 is much darker I'm using WARSHIP PICTORIL#27 and what I can on the web can someone point me in the right direction I'm posting photos of my build at it's current state thank's Glenn
1/72 U-boat 249
GuestTags: None
Originally posted by \
[ATTACH]16461.IPB[/ATTACH]
[ATTACH]16462.IPB[/ATTACH]
Its going to be pretty hard to say for sure. Alot of these boats went through different colours/shade/camo schemes depending on the captains preferance and what paint was left and the dockside. Ceratinly looks a darker shade on the b&w photo.Comment
Originally posted by \Its going to be pretty hard to say for sure. Alot of these boats went through different colours/shade/camo schemes depending on the captains preferance and what paint was left and the dockside. Ceratinly looks a darker shade on the b&w photo.Comment
Originally posted by \Hi Mankster the directive late in the war was to darken the boats to hide from hunter aircraft when at periscope depth. I also understand there was an attempt to camo the decks to break up the sillohette of the subs at periscope depth I have matched the color of U-805 spot on ,but I'm going hold off and make sure before I commit,but your right about them using what ever paint they had on hand, thank you for your help. GlennComment
Originally posted by \Hear are some photos of the build
[ATTACH]16463.IPB[/ATTACH]
[ATTACH]16464.IPB[/ATTACH]
[ATTACH]16465.IPB[/ATTACH]
[ATTACH]16466.IPB[/ATTACH]
[ATTACH]16467.IPB[/ATTACH]
[ATTACH]16468.IPB[/ATTACH]
[ATTACH]16469.IPB[/ATTACH]
[ATTACH]16470.IPB[/ATTACH]
[ATTACH]16471.IPB[/ATTACH]
[ATTACH]16472.IPB[/ATTACH]
Nice one Glenn,
looking good, i'm doing one myself depicting U-69 here http://www.scale-models.co.uk/under-construction/5116-1-72-revell-u-69-a.html if you would like to take a look. Keep the pic's coming.
All the best,
Sav.Comment
Originally posted by \Nice one Glenn,looking good, i'm doing one myself depicting U-69 here http://www.scale-models.co.uk/under-construction/5116-1-72-revell-u-69-a.html if you would like to take a look. Keep the pic's coming.
All the best,
Sav.
Glenn
[ATTACH]16488.IPB[/ATTACH]
[ATTACH]16489.IPB[/ATTACH]
[ATTACH]16490.IPB[/ATTACH]
[ATTACH]16491.IPB[/ATTACH]
[ATTACH]16492.IPB[/ATTACH]
[ATTACH]16493.IPB[/ATTACH]
I'm assuming you mean these vertical lines?
If so then it's Mig pigments mixed with white spirit and painted on with a fine brush. I'll scrub these down a bit to stop them appearing so stark.
Sav.Comment
All the best,
Sav.Comment
OHHhh!......them, God it's so obviouse now!
They are 3 dimentional tranfers, yes, THREE DEE!! They come from Archer fine transfers under thier surface details range and are a good way of adding the missing weld beads. You use them in the same way you would any decals. They are quite expensive but i managed to get away with using only one sheet. Have a look here ARCHER AR88005
You might like to do a quick Google on them as there are sites showing them applied and weathered.
Hope this helps,
Sav.Comment
Originally posted by \OHHhh!......them, God it's so obviouse now!They are 3 dimentional tranfers, yes, THREE DEE!! They come from Archer fine transfers under thier surface details range and are a good way of adding the missing weld beads. You use them in the same way you would any decals. They are quite expensive but i managed to get away with using only one sheet. Have a look here ARCHER AR88005
Hope this helps,
Sav.Comment
Originally posted by \Thank's Sav ,I've never heard of these before,very cool look's like they would save alot of time. I've always hade to make my own thank's for the info .I will check in to them and your boat looks realy realy good. Glenn
[ATTACH]16503.IPB[/ATTACH]
[ATTACH]16504.IPB[/ATTACH]
[ATTACH]16505.IPB[/ATTACH]
[ATTACH]16506.IPB[/ATTACH]
[ATTACH]16507.IPB[/ATTACH]
