hi all, i've just bought revell's 1/72 scale u-boat and a brass etch kit, having never had much to do with brass etch kits i was wondering what the best glue is to attach the brass to the plastic, thanks andy.
help please
GuestTags: None
Originally posted by \hi all, i've just bought revell's 1/72 scale u-boat and a brass etch kit, having never had much to do with brass etch kits i was wondering what the best glue is to attach the brass to the plastic, thanks andy. -
hi glen, its eduards kit, when you say "ca glue" i take it that you mean super glue cyanoacrylate, cheers andyComment
Originally posted by \hi glen, its eduards kit, when you say "ca glue" i take it that you mean super glue cyanoacrylate, cheers andyComment
I made the Revel kit with the White Ensign models PE set. Have a look through my build thread in the boats section.
I used a combination of cyano glue for the PE. Where I wanted a bit of support I used gel and where that was not necessary I used thin liquid. There really isn't any other type of glue that will hold such materials together. Glenn's suggestion to use the slow set stuff is a really good idea, and I wish I'd thought of it!!Comment
