Having made this model myself and knowing the sizes of these pieces very well I am absolutely staggered by the amount of detail and the size of the components you are working with. This model is absolutely superb and a pure joy to watch it go together.
Intro
Thanks guys!
Tweezers are in constant use during this build.
Some parts are so small, that without the tweezers it would be impossible to work on them.
Im back in the shipyard, and work started on the 88mm gun crew.
Im using Warriors set.
After asembly i cut out the imitation of the 88mm projectile from the hands of the loader- i will turn the new one from brass.
TBC...Comment
Hi:
Would you mind me asking how the best way would be to turn soft metal or if there is a way to do without a small mill? Maybe using a dremel chuck to hold the piece but not sure what would tool would shape it while spinning. I have the little workstation that acts like a small drill press. Thanks again, Siara!Comment
Thats exactly how i do it. Because i dont own the lathe just yet, im turning the wires, and tubing in the dremell tool. I bought the small diameter chuck for it, so i have choice of small, and large diameter.
The key is to use perfectly straight piece of wire- otherwise it will not turn right.
Hope it helps.Comment
Originally posted by \Thank you very much!! I really appreciate it! Jeff
Meanwhile.
Couple of test shots of the general layout of the scene:
TBC...Comment
I have aded the sights for the aimer, and the bracket only on the other side.
The whole gun was sprayed Chaos Black primer.
The support on the aimers side is extended to fit the figure, and on the other side one is in stowed possition.
TBC...Comment
Originally posted by \I have aded the sights for the aimer, and the bracket only on the other side.The whole gun was sprayed Chaos Black primer.
TBC...
Sorry.
AndyComment
Thanks Andy!
I started painting the 88mm gun:
Gun is ready to receive its share of oils, washes, and chips.
I also applied the base colour on figures:
TBC...Comment
Thanks guys- thats to kind.
Weathering cont.
First the oil stains:
Then the soft pencil for raw metal scratches:
TBC...Comment
