Fenghua 0.2 mm Nozzle Double-Action Airbrush BD-180
    Available from Scale Model Shop.
    Price £15.99
    Specification taken from the Scale Model Shop.
    Pack Size: 18.8 x 11 x 3.6 cm
    Package weight: 0.294 kg
    Recommended Age: 8 + (unsuitable for ages 0-3)
    Top filling universal steel dual function airbrush gun with permanently integrated cup. The amount of paint and the amount of air can be individually regulated. The valve can be adjusted for high precision air pressure control.
    These Airbrush Spray Guns are very popular amongst users, with an excellent fit and finish and low price.
    Package Contents:
    1x plastic box
    1x airbrush spray gun
    1x Mounting key for nozzle
    1x lid cup
    1x hose connection nipple 6x4
    1x cap nut
    1x manual
    This airbrush gun is suitable for commercial spraying, cosmetics, nail studios and Tattoo designs, illustrations, hobbies and modelling.
    dual-function spray gun airbrush
    top filling gravitational system
    Integrated gravity cup with lid with a capacity of 9 ml
    steel nozzle with a diameter of 0.2 mm
    stainless steel needle 0.2 mm
    Teflon gasket resistant to solvents
    adjustable needle stop
    pressure: 1 - 3.5 bar (15-50 PSI)
    air connection: screw G1 / 8
    Gun weight: 108 g
    Gun length: 159 mm
    John, at Scale Model Shop sent me one of these airbrushes to try out and write an honest review. I can tell you right now, I will be getting one and here is how I got on with it and why I want one.
    Straight away, can an airbrush for £15.99 be good as one ten times the price. Well, the honest answer is yes and no.
    Yes because it can spray paint in a way that is suitable for modellers. No because at that price, it cannot be the same quality of engineering or materials.
    However, the true test in a tool like this is not scientific it is simply a case of does it do what you need it to do as a modeller.
    Lets take a look at the airbrush.
    It comes in a plastic hinged lid case with a cut-out foam insert
    The airbrush carries more than a passing resemblance to a very expensive model produced by one of the leading airbrush manufacturers. However, there is not that many ways an airbrush can look so this should not be taken into account really.
    The airbrush is what is known as a gravity feed double action brush.
    Gravity feed means that the paint in the colour cup sitting above the airbrush is transferred to the nozzle by gravity rather than suction.
    Double action is the way that the trigger situated roughly in the middle of the barrel on top controls both the airflow and the paint flow. The air is controlled by pressing the trigger down. The further down you press it, the more air is allowed to flow towards the tip.
    Pulling the trigger back pulls a tapered needle, which sits firmly in the nozzle blocking it, backwards out of the nozzle which allows paint to enter the nozzle and get picked up by the airflow resulting in an atomised spray of paint leaving the business end of the airbrush. The further you pull the trigger back, the greater the paint flow.
    Additionally, this airbrush has two pre-set controls. To the rear of the main barrel is a screw that allows you to limit the distance that the needle can travel.
    Below the barrel directly below the colour cup is a screw adjuster that can be used to set the airflow from off to fully open.
    So, why do you need these if it has full control through the trigger?
    Consistent control using the trigger on any airbrush at any price is a skill. It is a skill that some pick up easily and some, like me, don't. This fine control, balancing how far you press the trigger down and, at the same time, pull back is something that beginners find quite tricky. I also find it tricky as I do not have great control with things like this as my hands are getting on a bit and are not as supple as they used to be.
    The pre-set controls remove this problem as, with a bit of trial and error, you can match the airflow to the restricted paint flow to help get consistent fine lines.
    Not as quick and convenient as using the double action trigger but are very welcome to people like me who struggle to work the trigger easily.
    The business end of the airbrush is where the atomised paint comes out. The standard end cap on this airbrush is quite a nice fine petal shaped tip. This is not simple an aesthetic thing. The shape and spaces within this cap can determine how the paint flows effectively without allowing the paint to dry out and build up on the nozzle/needle tip which will cause splattering and spitting resulting in a poor paint finish.
    Some airbrush tip designs have a paint nozzle that is quick and easy to remove for cleaning but is held in place by the end cap. This airbrush has a screw in nozzle which requires very gentle and careful us of a supplied spanner to remove and fit it. Although this is less convenient it does allow you to remove the end cap and spray very close fine lines but, with care as the fragile needle tip is exposed.
    This is something I cannot do with my budget H&S Ultra airbrush
    To remove the tip for strip cleaning the two part cap is removed to give full access to the nozzle which on this brush is a fine .2mm
    To remove the needle, the barrel back end is screwed off and the locking nut is loosened allowing the needle to be drawn back and out of the airbrush.
    That then is the brush but does it work?
    Well, yes it does. In fact it works very well. My initial test was just to spray water through it so I could get to see the spray pattern. This is important as a badly shaped needle or nozzle can cause the spray to veer off at an angle or change the shape of the spray. What you are looking for is a distinct conical pattern running parallel to the needle.
    In this respect I was more than happy with the spray pattern and, by using the pre set controls, I found that the changes in pressure and flow did not cause any distortion to the spray pattern.
    To test it for real, I made life a tad tricky for myself by using a primer I had never used before thinned using IPA which also, I had never used before.
    So, to try it out I mixed some primer at roughly 50/50 with thinners and added it to the large colour cup. First I tried some spraying on a paper towel just to see how it worked. I realised that the paint was still a bit thick, I hadn't measured it accurately, so I dropped some more thinners into the cup, mixed it with a soft brush and carried on with no problems.
    This may not seem all that special but this primer is clearly recommended to be sprayed using a .4mm needle set, twice the size of the one fitted to this brush.
    I then selected my target for the test, my current armour build. This was not going to be a full prime as I still have a few things to add, I just wanted a quick coat to see how it works.
    I am happy to say that it worked very well. The paint flow was great, coverage was what I wanted and the finish is superb.
    Conclusion
    This is a very nice airbrush. Compared to my H&S Ultra, the needle travel is greater but this is just something to get used to, all airbrushes feel different so it isn't a negative.
    However, I found the pre set control very handy, something I think I need more than I realised. OK, it is a bit clunky compared to the top end brushes but as it costs between ¼ to 1/10th of the mid range to top end, I wouldn't expect anything else.
    As an airbrush, it does what it is supposed to do and it does it well. There is a .3mm needle and nozzle set available for it for around £4.00. which is ridiculously cheap! Will it last as long as top end airbrushes? Well, that is subjective. Looked after well, it will last the average modeller far longer than it's price suggests, in fact, it will probably be the modeller that moves on to bigger things before the brush turns up it's toes.
    So, who would I recommend it to? Any airbrush beginner who is in the market for their first brush? Certainly. No matter what brush a beginner gets, they have a lot to learn and this brush will allow them to do it especially using the pre set controls.
    If you have a medium to top end airbrush is there any point in you getting one? Well, for a total of £20, get the airbrush and the .3mm needle set and you have a great dedicated primer or varnishing airbrush.
    Would I get one? Answered this one already, yes I will. Like any airbrush I need more time to learn how to work better with it but this would apply if I spent £120 on a top end brush.
    So why doesn't it cost more. Partly due to buying power and partly because it isn't as highly engineered as top class brushes. However, having used many brushes at slightly more in cost but less in features, I would say this brush is as good as any budget brush twice the price.
    Highly recommended as a good quality budget airbrush and I will sign off this review with the airbrush
    A very good review Graham, no doubt it'll be helpful to anyone who's considering buying an airbrush.
    The ability to remove the crown cap is very useful for getting in close & doing fine lines. It's something that I miss in using my H & S Ultra.
      Can't wait to spend more time with it Patrick. It was the first time in ages I have slapped some paint in an airbrush and sprayed something without having to strip and clean it until the end.
      • Robert1968
        • Mar 2015
        • 3596
        Totally sold it to me Graham and I'll be sending John message to put one in basket for me with the needle extra set too
        I use Iwata Eclipse as main A/b but this would be ideal for as you say varnish or primer or small part spraying
        Ps can I get a signed autograph?
        Robert
          Robert
          Just save the picture mate
          • Robert1968
            • Mar 2015
            • 3596
            It will last longer!!!!
              Disappointed that i've already bought one now. a week earlier and I would have got this in a heartbeat! Can you review a budget end compressor/electric airpump before I go and spend more than nessasary on one?
              Great review, next a chat show and a book.... That autograph might be worth a fortune one day!
                Well, being as I don't use acrylics much, I find cleaning & stripping my AB is not something I do much. In fact, my personal opinion is that too much cleaning causes many of the problems that people encounter with airbrushes.
                Although my Ultra clearly possesses a higher grade of engineering & machining as evidenced by the smooth trigger action for instance, a cheaper one could conceivably prove to be better value in the long run.
                If we consider our use age & cleaning regimes that can potentially cause cumulative damage to our more expensive airbrushes, then replacing one that costs under £20 every 6 months could be worthwhile.
                If we bought a £200 airbrush that was kept for 5 years, we could have a brand-new £20 one every 6 months in that same 5 year period. Worth thinking about!
                  Stuart, it's worth considering that some items are less subjective than others. For instance, a watch might be the same for most people if it has the features they want. Some products, like headphones or loudspeakers are more of an individual choice.
                  Airbrushes are just like that. Some 'fit' in one person's hand, others feel uncomfortable. Likewise, compressors. To some an average one will seem noisier, whilst it might not bother another person.
                  Personally I don't think there's any great difference between one costing £80 or £200. Often it's the brand that increases the price.
                  If you plan on doing 1-2 hours spraying a day, get an AS 186 with a tank. That'll set you back about £70.
                  If you want to spray at unsociable times, get one that is pistonless - they're much much quieter. These ones are more expensive, but if you have a reuse & recycle centre near you, a fridge compressor will do the same job for about £30. Add the tank & pressure fittings for maybe £60 or £70 (depending on the tank capacity).
                  • Robert1968
                    • Mar 2015
                    • 3596
                    Well I just git confirmation from John that I'll be getting the new Fengdu Airbush for £20 with extra needle and I think it's coming the same time the compressor comes. I'm going fir the Fengdu AS189 which is simular to the AS186 both with tanks
                    From what I've read and seen on this new A/b it makes sense to buy as a second airbrush. My main is iwata eclipse which I find very good indeed.
                    Regards
                    Robert
                    • tanktrack
                      • Jun 2012
                      • 1429
                      some times less is more , I have 3 airbrushes , 1 a cheap Chinese 1 and a mid and top iwata range and for basic work they all do the same thing well , my biggest bug bear with brushes is the trigger buttons as my finger gets sore after a few mins I don't think its because I'm left handed ? .
                      • stona
                        • Jul 2008
                        • 9889
                        Very nice review Graham and very helpful as well. We often see people asking the 'which airbrush' question.
                        I would give one piece of advice, applicable whichever double action brush someone is using. Don't try and control the air pressure with the air valve on the brush, set it at the compressor or MAC valve on the airbrush if it has one (Iwata do an external MAC valve which fits any of their airbrushes for about 20 quid). When painting always depress the trigger fully to enable the air and then pull back to introduce the paint (or other medium).
                          Totally agree Steve, I got a MAC valve for my H&S Ultra. The air valve on this brush in fact acts as a MAC valve built in so best of both worlds
                          • ojays
                            • Oct 2011
                            • 1713
                            Is this AB suitable for cellulose use, ( ie: does it have rubber or Teflon seals) please.
                            Gregg
                            • John
                              • Mar 2004
                              • 4642
                              • John
                              • Halifax
                              I once asked the airbrush company the same question about the Neo which doesn't have a Teflon seal, they told me that because of where the seal is it should affect it
                              www.scalemodelshop.co.uk
