Just bought a set of Dspiae STA 3.0 nippers, no idea how you say it!!
This is my review, of course you may disagree!
The nippers come in a excellent box, instructions, pouch, limit adjuster, and cleaning cloth
Above on the right is a panel you scratch off the lower part which reveals a 16 no code, next visit there website. You input the code to check if its fake, thankfully mines ok!
The handles are very comfortable and in the box is limit adjuster to set the gap between the blade and stop. If set wrong or not checked the cutting blade will be ruined!
I have used sprues from the Daring shambles, by the way its recommended not to cut 3mm or thicker plastic, no metal as well!
This is a very close cut using the Dspiae nippers, as you can see no stress marks just a flush and neat slice, very little to clean up.
This is Tamiya, again close but you can see the stress mark and it has rough feel
As you will know you sometimes have to put in a bit of effort and can hear a 'click' as it cuts, with the Dspiae, nothing, no effort at all just a very light touch.
Also cut off some very small parts, with the Tamiya i have the the normal fear of the part taking off as you cut into the plastic! With the Dspiae set, no need to worry, very neat cut no damage and the part stayed still, thank god!
I paid £30 on ebay, i have found a Tamiya set £27! Would i recommend them, yes every time
Will of course still use the Tamiya set for thicker plastic.
Hope this is helpful?
Bob
Bob
