Trumpeter 1/700 US Navy Aviation Set WWII 03418
    8 different aircraft 6 of each, except the Mitchell of which 4 are supplied. Sturdy box, the 16 sprues are wrapped in foam, as Trumpeter practice. These are moulded in grey plastic............
    Mitchells & Devastators
    Avengers & Wildcats
    Corsairs & Helldivers
    Dauntless & Hellcats
    Instructions - if needed!
    Decals - 7 sheets! - must be a mistake - 4 would do!
    The parts are cleanly moulded, some of the propellers will be tricky to remove. No painting guide, but a few minutes on the 'net will sort that.
    Availability - a bit patchy, but yes, I would cast around around, the box itself is around £13, but you can find sellers that do free p&p!!
