Yamashita Hobby 1/700 IJN Destroyer Take - Inbox Review
    I've not had a Yamashita Model before - this was purchased from Japan by surface mail ( < 3 months ).
    The Take was a 'Mutsu' Class small destroyer - launched in 1943 - it actually survived the war!
    The back of the end opening box has the colour profile
    Sprue shots......................Click image for larger version
ID:	1184498Click image for larger version
ID:	1184497Click image for larger version
    All the sprues are very cleanly moulded with some slide moulding. Bear in mind this is a small destroyer 140mm long X 11mm beam.
    Instructions are clearly printed at a good size......................
ID:	1184508Click image for larger version
    Some detail shotsClick image for larger version
ID:	1184501Click image for larger version
    Hull plating vastly overscale - but it's there!
    The baseplate/central bulkhead - a bit belts & braces!
    Fine moulding - bottom planks on boat - sprue attachments OK, considering the size of the parts!
ID:	1184505Click image for larger version
    Swann-Morton 10A scalpel for size comparison
    I'm pretty impressed with this model it makes the Tamiya/Fujimi/Aoshima/Pit Road offerings look very much last century. The other maker who produces similar detailed models is Flyhawk.
    These models are not very common - I had to buy mine from Japan, where there are models that never seem to have exported to the West! Prices vary a lot, if you add in airmail, then they are pretty expensive. I trialled surface mail & the total cost was a few pennies over £11, but I had to wait nearly three months. It wasn't tracked ( really cheapest delivery! ), so you can't be sure it hasn't gone astray - which is why I did the trial with a cheap model. You'll probably be OK, but I'm going to stick with one of the mainstream retail outfits in Japan - Hobby Search.
  • adt70hk
    • Sep 2019
    • 10409
    Looks good Dave, especially for the size?
      • 18907
      That looks excellent Dave. Plenty of small bits for the carpet monster to chew on
