Sil-air 15D
  • Bri62
    • Jan 2023
    • 1879
    • Brian
    • Widnes Cheshire
    Sil-air 15D
    Bought myself a silent compressor and must admit I'm impressed, when it kicks in it's so quiet the actual air brush is louder but getting to the bottom of the air/drain glass to blow it down after a session is a pain (minor gripe)
ID:	1218878Click image for larger version
ID:	1218879Click image for larger version
  • Andy T
    • Apr 2021
    • 3239
    That does look a bit tight.
    • Waspie
      • Mar 2023
      • 3488
      • Doug
      • Fraggle Rock
      Looks fine. Maybe pop it on a stand and drill a large hole under the drain glass to allow access!!
      • Bri62
        • Jan 2023
        • 1879
        • Brian
        • Widnes Cheshire
        Thinking the same myself ,,,,,but you shouldn't have to
          • 18901
          Originally posted by Bri62
          Thinking the same myself ,,,,,but you shouldn't have to :smiling3:
          Isn’t the large hole already there? I can see the carpet through it in the second picture. I would also be tempted to fit a secondary PRV at the airbrush stand to control usage air pressure. You would then just need to wind up the pressure on the compressor and only access it once to drain down when you finish the spray session. Andy has something like that illustrated in his new room thread, as do I in my room. It really makes life much easier.
          • stillp
            • 8091
            • Pete
            • Rugby
            Is there a drain valve under the actual tank?
            • Bri62
              • Jan 2023
              • 1879
              • Brian
              • Widnes Cheshire
              Yes Pete the manual says to drain once a month
              • Scratchbuilder
                • Jul 2022
                • 2689
                You do not need to drain after every session, mine is only drained when I remember and normally there is very little water. (pause) In fact just checked it now and nothing... The time you are most likely to have a moisture problem is in high humidity or freezing conditions eg a cold shed. The poor thing needs a good dusting is about all.
                  • 15679
                  I have never had any moisture in the glass/drain thing. At the end of an airbrushing session I release the pressure by removing the drain plug in the bottom of the tank. That blows out any moisture and I leave the plug out until the next time which helps keep the tank aired and dry. I do work inside so the room is always warm.
                  • Andy T
                    • Apr 2021
                    • 3239
                    I can attest to this.
                    When working out in the shed I drained my tank every time I used it as there was always some moisture following every session.
                    Since moving indoors I haven't had a drop out of it.
                      • 18901
                      I always have about five mil of water in the moisture trap on my pressure regulator after use, but the compressor is tankless and the PRV is where decompression happens, so that’s where it gets made and caught. I’ve only ever sprayed indoors. We’re on Somerset clay and the garage has no damp proof membrane, so if I tried to use the garage I’d need to put the bench on a rubber boat……
                      • JR
                        • May 2015
                        • 18273
                        Wibble
                        Would heat or flame do ?
                        Wobble.
                        Taxi .
                        • David Lovell
                          • 2186
                          Like Mike ill pull the tank plug to drain it when I remember ,there's a moisture trap under the pressure gauge with a little pull down valve plus ive a moisture trap fitted directly to the airbrush(silver bullet/sparmax) but to drain out the air ive a key ring thing I pull to empty the holding tank in one big hiss. Dave
                          • Scratchbuilder
                            • Jul 2022
                            • 2689
                            Originally posted by JR
                            Wibble
                            Wobble.
                            Taxi .
                            LOOK OUT!!!! Some fool has sold him a box of matches.....
