Ship building berth
  • BattleshipBob
    • 6790
    • Bob
    • Cardiff
    Ship building berth
    My previous reviews have caused wars and people leaving the site, so fingers crossed
    John did ask for a review so blame him lol. Was going to do this Tuesday but mum's not at all well, so other things on my mind sorry.
    Right here goes
    I have always had problems keeping a ships hull safe from damage etc after it's painted. Especially adding the superstructure. Tried a foam device, because it was of course only one size, its not much use. Placed hulls on bubble wrap but it still moved around.
    Most kits have useless plinths which do not securely hold the hull.
    So noticed on eBay a 3D building berth, available small for 1/700 - 1/350 or large 1/350 - 1/200. I bought the large one, £22.50 with free p/p. The seller on eBay was very helpful, fast delivery as well.
    The bits
    The black strip is sticky backed foam packing for the clamps. The round discs are padding for underneath
    Very easy to assemble
ID:	1221310Click image for larger version
ID:	1221311Click image for larger version
ID:	1221312Click image for larger version
    Our new rescue moggie, Luna has no interest at all!
    To adjust simply undo the wingnuts and slide the brackets to suit. To mount a 1/200 hull, move the bracket to the other side of the arms support moulding.
    Minimum clamp size: 3.8cm, small hull max width 9cm, larger hull max width 19.5cm.
    Below max width 19.5cm
    Fletcher mounted
ID:	1221315Click image for larger version
    Did the clamps up tight and no marks on the paint.
    Only slight issue, the actual clamps are flat so not a perfect fit on the destroyers sloping hull. However the clamps should have no problems holding the mainly flat hull sides of a battleship.
    Looks a well designed and made product. Will use on the German destroyer I am building once the hull is painted, that of course will be a real test.
    The seller also makes clamps for planes, cars etc.
    Hope this is ok and of use
    Bob
    • 18889
    Looks well suited to the task Bob. I think I’d be tempted to fix the base to a wider offcut of chipboard or MDF to increase its stability before putting a big boat in it though.
    • BattleshipBob
      • 6790
      • Bob
      • Cardiff
      Hi Tim, was wondering about doing that plus using bubble wrap along arms the clamps are attached too, but not fixed to them?
        • 15653
        That looks well made and not a bad price. Worthwhile Bob and if it saves one disaster then a good buy.
        I reckon the flat faces to the clamps could be easily sorted with 4 triangles of hard foam temporarily fixed to the clamps with a bit of double sided tape.
        All the best to your mum at this tough time.
        Just found the seller on eBay. A lot of useful stands at reasonable prices.
        • boatman
          • Nov 2018
          • 14451
          • christopher
          • NORFOLK UK
          LOOKS very good Bob matey good review you have done but would it hold my tiger lol but i think bri could have done with this for his sub to save from dissater but well done my good freind
          chrisb
          • adt70hk
            • Sep 2019
            • 10400
            That's very good indeed Bob!!
            • BattleshipBob
              • 6790
              • Bob
              • Cardiff
              Hi Jim, good advice. The seller was quick to reply to my question and was very helpful to be fair.
              Don't think mum's got too long, every visit is now distressing as she's lost so much weight and is so frail
              • BattleshipBob
                • 6790
                • Bob
                • Cardiff
                chrisb
                Thanks Chris, further builds will test it!
                Hi Andrew, should do the job well
                  That looks pretty neat indeed!
                  • adt70hk
                    • Sep 2019
                    • 10400
                    Bob, can you PM me the link to see what else he has. Thanks.
                    • BattleshipBob
                      • 6790
                      • Bob
                      • Cardiff
                      Morning Andrew
                      Go to eBay UK, search building berth.
                      Bob
                      • adt70hk
                        • Sep 2019
                        • 10400
                        Morning Andrew
                        Bob
                        Thanks found it......was using slightly wrong term before......he's got some interesting looking stuff!
