boat section posts not showing.
  • BBdave
    • Aug 2014
    • 825
    How come posts in the boat section don't pop up on the recent threads section? are we not worthy?
    I have visited all three topics in Ships and Boats and lots of images appear there. There aren't any in the present Recent Threads topic so I can't check there. Try posting a test post (call it "Test" for easy identification) with an image (any image) and I will look out for it.
    • spanner570
      • 15389
      Strange that.....I count four on the first page alone. All accessible.
        Did you find those on the "Recent Threads" topic, or the "Ships and Boats" topic. I think the OP was referring to there being no images in the "Recent Threads" topic.
          Hi all I have asked this question before, if I post in "tanks/dio's or planes it will show up in the forum on main page, but if I post a build in Boats I have to look in recent posts to find it.
          • Alan 45
            • Nov 2012
            • 9833
            It doesn't show on the home screen , it does if you click recent posts
            • eddiesolo
              • Jul 2013
              • 11193
              Yep, doesn't show up in latest threads.
              Si
                • 18266
                I can see two ships under construction in the "recent threads" bit.
                Are you posting in SHIPS or BOATS?
                I have had a look in the gubbins and all the different forums are set up in the same way... I will have another look but at the moment I have no idea why this is happening. Or not happening o.O
                • BBdave
                  • Aug 2014
                  • 825
                  Yes when a post is put in the boats/subs. under construction it doesn't show on the home pages recent threads,
                    • 18266
                    I just made a post in the Gato sub build and that showed up in the recent threads....well on my lap-top
                    Ian
                      I can see two ships under construction in the "recent threads" bit.Are you posting in SHIPS or BOATS?
                      I have had a look in the gubbins and all the different forums are set up in the same way... I will have another look but at the moment I have no idea why this is happening. Or not happening o_O
                      I have just looked again at "Recent Threads". I saw no ships or boats there, and that was true about an hour ago, and again now, 55 minutes after your post (referred to in the QUOTE), and 28 minutes after your later post.
                        • 18266
                        Well I am flummoxed. I think we might have to get the boss on this one.
                        "John!?" he called out into that inky darkness that we call the Interweb.....
                        • flyjoe180
                          • Jan 2012
                          • 12390
                          • Joe
                          • Earth
                          I can see the maritime builds in their respective recent threads. I can see that just a few minutes ago Monica posted in the submarine build thread, and that shows up in the 'Recent Threads' section as well as in the 'Ships, Boats and Submarines Under Construction' menu.
                            I can see the maritime builds in their respective recent threads. I can see that just a few minutes ago Monica posted in the submarine build thread, and that shows up in the section as well as in the 'Ships, Boats and Submarines Under Construction' menu.
                            That's puzzling. I cannot see Monica's post that you mention anywhere, not in 'Ships, Boats and Submarines Under Construction' nor in 'Recent Threads'. (!!!) However, it might have slipped off 'Recent Threads' by now, due to time passing.
                            • BBdave
                              • Aug 2014
                              • 825
                              It certainly isn't coming up on the home page tonight could it be an ipad thing?
