Winking smiley
    Odd. It takes the wrong smiley from the set, which means the coordinates are off. Did you put [ICODE]styles/default/xenforo/smilies/emojione/sprite_sheet_emojione.png[/ICODE] in the first field for the image replacement URL, or in the second one (labeled “2x image replacement URL”)? That seems the most likely cause for it to be taking only a quarter of the wrong smiley.
    Also, I get the impression the word [ICODE]winks[/ICODE] is in the “Text to replace” field.
    • John
      • Mar 2004
      • 4646
      • John
      • Halifax
      #17
      As I said those are the settings that I put in, and yes winks is the replacement word, but I've now removed it
      www.scalemodelshop.co.uk
        I figured it out: the box at the bottom of the smiley settings needs [ICODE]100%[/ICODE] put into it. If you don’t, the coordinates will be off and the result is what we had at first.
        • John
          • Mar 2004
          • 4646
          • John
          • Halifax
          #19
          I don't know where I'm meant to put that, there isn't a box for percentage, I've just added the little winker in
            It’s labelled “Background size”:
            [ATTACH]370516[/ATTACH]
            • John
              • Mar 2004
              • 4646
              • John
              • Halifax
              #21
              So it is, but now it does't work
                It works fine for me if I test it now:
                So thanks for making it work!
                • stillp
                  • 8097
                  • Pete
                  • Rugby
                  #23
                  test
                    Originally posted by stillp
                    test
                    I saw the headline and I thought, are you all looking for one, or are you telling us that is what you do in your spare time....
                    • Bortig the Viking
                      • Mar 2019
                      • 780
                      #25
                      Must say when I saw the thread heading I had to read twice, slightly misread it. :flushed: :smiling3:
                        I know - winking.....
