Adding Attachments
    Adding Attachments
    I wish to add some attachments to a post regarding resent build.
    But I keep getting this message
    "Your submission could not be processed because a security token was missing.
    If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error."
    Can anyone help with this. There are 6 attachments that I wish to add and the are all Jpegs of the Project.
    Many thanks
  • John
    • Mar 2004
    • 4638
    • John
    • Halifax
    It seems your not the only one with this problem, I'm not sure what is causing it I've made the changes I thought would sort it but I guess it hasn't and because I don't get the error it's hard to find what is causing it, can you upload your pictures to the gallery for now and use the code in [ IMG] [ /IMG] tags (remove the spaces between [ I & [ /) I will look in to the problem again see if I can fix it.
    www.scalemodelshop.co.uk
    • John
      • Mar 2004
      • 4638
      • John
      • Halifax
      I've just found this
      If this problem is only happening to some people and cannot be reproduced, the probable cause is their browser cache. Have these users either try a different browser or clear their browser cache.Otherwise an ISP cache may also be to blame.
      Can you try that and let me know?
      • John
        • Mar 2004
        • 4638
        • John
        • Halifax
        • John
          • Mar 2004
          • 4638
          • John
          • Halifax
          I've made some changes that should hopefully fix it, please let me know if it's working for you now
            I have tried everything you have suggested.
            I am using Firefox as my browser.
            I have tried to do the same thing using Internet Explorer but still get the same message.
            Very strange
              AH HA Success (well sort of)
              I found that if I tried to upload more than 4 pictures at a time the upload failed and showed the message.
              Less than 4 it worked fine.
              I was trying to upload 7 pictures, so I done 1 batch of 4 and then 1 of 3 this appeared to have worked.
              Hope this helps
              Many thanks
