This short tutorial will walk you though using the manage attachments to post your images in your threads.
In full screen editor select manage attachments
That will bring up a new box. if you have a pop up blocker make sure you add scale-models.co.uk as a trusted site.
Click the Add Files button in the top right corner
Then press select files to bring up the selector box. Browse to the file located on your computer, press Open
You can select more than one file, when done press Upload Files
After a few seconds your uploaded file will show in the bottom of the box, if you want to use other images you have uploaded before just drag an drop to the bottom box, then press Insert Attachments.
If everything goes ok you should see the images now showing under your Manage Attachments button.
Complete your post and Submit New Thread, your images will now show as thumbnails within your post.
