Mark can you try it now, if it's the search that's a problem I will move it somewhere else, I've removed it for now
new layout
logged in with 2011 presentation.. the top corner is good now.
However, when trying to log on with new presentation, accessing the logon and password boxes is difficult. When I do enter name, I tab to password, but I can't click on loginComment
ok, tried again with new presentation. Once I enter name (getting the exact point to enter text is awkward, but once I enter name, I tab to password, then hit tab and "enter" (because I can't click on login )Comment
me again, sorry...
I'm using chrome and logged in with new schema. but to access the top-right icons such as "settings", "logout" etc, I have to hover the mouse around the icon for a bit until the mouse pointer changes and then I can click the action.
I'll try firefox and IE and send you a PM with result JohnComment
Hi I also have to logon in a roundabout way. I can't enter either username or password I have to click logon and then enter details on the page that comes up to tell me i've put the wrong details in. Apart from that the new design looks and works fine. i am using Firefox version 18.0.1 in Mint linux. I have also tried using Opera with exactly the same result.Comment
Tried just about everything but my 2010 MacBook Pro just will not have it
I have also just tried my nieces 2012 MacBook Air with safari and that won't let me login either
The problem appears to be very similar to those the Firefox users are having
My mac is set to dual boot and when I boot into windows and use ie everything is fineComment
I use a Macbook Pro and a iMac and don't have any problems in Firefox but I do in Chrome, it's something to do with the left hand side of the forum as you can see from the attachments, if the boxes are over the left side the won't work, I'm not sure what it is but I'm getting closer to fixing it
[ATTACH]59666.IPB[/ATTACH]
[ATTACH]59667.IPB[/ATTACH]
[ATTACH]59668.IPB[/ATTACH]
looks like "frame" issues
is everything set in the frame or is it floating (to use old fashioned expressions)
Originally posted by \It only seems to affect Firefox on a PC, the Mac version works fine, for a temporary measure you can still choose the old style from the drop down at the bottom, then change back if you want and it will keep you logged in, I'm still working on a fixComment
John you've done a great job but I'm not sure I'm a fan of the new layout kinda like the headers and folders in a lighter colour it all looks a bit heavy. I also like the site being across the full page makes reading the posts a bit easier it feels like everything has been squeezed into the middle. Navigating round the site is a bit odd trying to looking for under construction and trying to find my posts and threads. Logging in has not been an issue as, I'm on a Mac using Safari, I've set it so I'm automatically signed in when I open the site. I suppose each to there own on this one maybe I'll give it a go again.Comment
You can now choose a fluid version of the style from the drop down at the bottom, Vaughan I've changed it in your preferences so it defaults to the fluid oneComment
