Trying to write out a few sentences in a few posts but cannot start a new line when I press return/enter. The curser won't drop down to the next line. My keyboard is defo working so is there an issue with the site John?
Return/enter not working
I had this a short while ago as well, the only way I could get it to work was to click on the A/A button just above where we type, the switch editor mode button. but I still have to then redo it to continue to type on each new post.
Adrian -
Its never been an issue till last nite, but if you click on the Switch editor to Scource mode tab it works, well it does for me.
AdrianComment
I've tried it on a ipad and on my Mac using Safari and Firefox, also tried Windows 7 IE9 and still no problems, it could be an issue with IE10, have you tried Firefox?Comment
I did notice this morning when I turned on my monitor a 'Welcome to your new Outlook', I paid it no attention but I know it did resart my PC as I need it to keep running all the time to work some software for an online game I play. Screwed that up also as it shut down the programs and they didn't restart. Be ready to accept your problems when they do this to you guys.
It has also had an effect on how you upload pics to I have noticed, you have to keep hitting the switch editor tab.
AndyComment
One thing you might want to check to see if it's been altered is the message box interface in general settings, the message interface should really be set to WYSIWYG (what you see is what you get), this gives you full access to all the functions in the text box.
Some browsers, however perform better with the enhanced version, so best to try both .... just ignore the simple editor it's just a basic typing interface.
I've switched through the skins and the fixed and fluid versions seem to have a glitch on my PC where i press return and nothing happens to the curser.. though if i type anything it moves down to the next line as it should do.
I have no issues with the 2011 skin which is the skin i use by choice anyway.Comment
I'm on the 2011 Colin and that seems to have the problems, I guess you haven't had the outlook upgrade yetComment
