Begginer advice?
  • stona
    • Jul 2008
    • 9889
    #31
    As you say it's about what suits you. I first started spraying..ahem....a while ago using Humbrol enamels which were just about all that was available then. They were very good. I chose to switch to acrylics mainly to reduce the odours. At that time I had neither the booth/extractor, nor the space which I now enjoy. I tried Vallejo (both) Xtracrylix, Lifecolor and probably a couple more. I was never really happy with any of them during the two years I used them. I did get some decent results, particularly with the Xtracrylix, but why should I be adding retarders and flow aids to a purpose made product? I bought a couple of WEM Colour Coats for the colours which I needed on a project, being enamels I had no trouble spraying them, loved the results and more or less gave up on acrylics and reverted to enamels there and then!
    • flyjoe180
      • Jan 2012
      • 12381
      • Joe
      • Earth
      #32
      I have a few Humbrol enamels that are over 30 years old and still perform. Do enamel paints last longer than acrylics when stored?
        Vallejo, Joe, say their acrylics will be fine for at least 5 years. Various have been tested at 10 and 20 years and have been found to be OK.
        But they say water will eventually evaporate and the pigment sink to a lump at the bottom.
        Humbrol or other enamels not a clue.
        • flyjoe180
          • Jan 2012
          • 12381
          • Joe
          • Earth
          #34
          Thanks Laurie. The old Humbrols just needed a stir and they are ready again. Saved me a small fortune in paint when I got back into the hobby.
          • aaron
            • Oct 2011
            • 2019
            #35
            Me too Joe, I have humbrol paints that have lasted for years.I even have some of the polishable metalizer that is still fine.
            I use both acrylics and enamels on the same kit...I love them both.
            • stona
              • Jul 2008
              • 9889
              #36
              Good on you Joe. You are obviously the meticulous sort who cleans the top of the tinlet and lid before sealing the paint in. I too have some 20+ year old Humbrols that still work absolutely beautifully, but being more slapdash in my younger days I've lost a few by failing to put the lid on properly too.
              • dave
                • Nov 2012
                • 1828
                • Brussels
                #37
                As someone who recently returned to the hobby I have 20+ year old Humbrol enamels and Tamiya acrylics that are fine, although the Windsor and Newton Inks had faded. I have always used a mixture of enamels and acrylics with artists oils and acrylics added to the mix, depending on the effect I want and the colours I have.
                I use both Vallejo Model Colour and Model Air for airbrushing and I have to say the Model Air is better. I thin my Model Colours with the Vallejo thinner but I still have more problems. I also brush paint with both, but I routinely thin Model Colour with a distilled water/flow enhancer mix.
                Which I buy depends on colour availability and if I think I will be airbrushing or brush painting most with that particular colour.
