compressor : is this a record.
  • flyjoe180
    • Jan 2012
    • 12381
    • Joe
    • Earth
    #16
    Aw c'mon Laurie, the dark side calls your name...
      Certainly showed my dark side Joe when I found the 5th compressor up the pole and a certain person way up in the ether received an unhealthy petition.
      • eddiesolo
        • Jul 2013
        • 11193
        #18
        Five in four years...you haven't got a job on the side spraying full size vehicles?
        Si
        • eddiesolo
          • Jul 2013
          • 11193
          #19
          Five in four years...you haven't got a job on the side spraying full size vehicles? Maybe something like this may work better...have you got a room?
          Si
            Five in four years...you haven't got a job on the side spraying full size vehicles? Si
            Si if I had a compressor which worked even every now and then I would give it a try.
              Perfect Si. Are they reliable ? Can you purchase them on line. Thinks I wonder if Pauline would mind sleeping in a tent.
              • eddiesolo
                • Jul 2013
                • 11193
                #22
                Perfect Si. Are they reliable ? Can you purchase them on line. Thinks I wonder if Pauline would mind sleeping in a tent.Laurie
                I am sure Pauline will understand as will your neighbours and the Island as you power it up and the lights dim.
                Si
