Linked to build http://www.scale-models.co.uk/community/threads/merlin-hc3-airfix-1-48-afganistan.19993/.
Hope (really hope and pray) to do some fine work with an airbrush. This is applying a mixture to represent sand clinging to the fuselage.
Vallejo Air thinners is generally the only thinner I would use.
But with fine work it is slightly thickish and for smaller nozzle/needle size .2 perhaps not perfect. Not perfect for me for this case in point as I have found out.
I am after a thinner, obviously compatible with Vallejo, which is thin. Water is no good as it has surface tension. Seen a number on here use alternatives.
Any help would be much appreciated.
