Hi gents , set up this morning with a Iwata revolution BR to do a bit , ab spraying air no problem loaded cup with water to give it a blast through , a few bubbles in cup but nothing coming out , gave a good clean with cellulose thinners no blockages super clean , re-built re-loaded same issues ? tried stripping cleaning trying again numerous times still no good ,
Swapped compressors , changed a new needle to 2 old ones - same issues , I`m now thinking it could be a problem with the o rings in the air valve area , I`ve put up a couple of photo`s but to me the ab and o rings looks ok ,
I tend to use a lot of solvent paints and cellulose thinners which does not help but thought I would ask you guys if it could be something else or I`m having a blond moment . I think I may have answered my own question but would like a few opinions before I spend ยฃ25 on spare parts.
any advice would be very much appriciated
Richy
[ATTACH]91470.IPB[/ATTACH]
[ATTACH]91471.IPB[/ATTACH]
Richy
