Help!! I've cleaned this Airbrush a hundred times now, but this is still happening:
When I spray, I'm getting good coverage, but I'm getting the occasional splodge that goes miles away from where I'm pointing the brush!
I can mitigate it by restricting the needle travel, but naturally this then means it takes an age to paint anything. I've got away so far as I was doing the under carriage, but I'm about to crack on with some camo paint and this kind of splodging will not do on a visible surface!
Any pointers gratefully received.
I've got a cheapo brush which was fine up until recently. Cleaned, cleaned and cleaned again. Running at 20psi using brand new Vallejo Model Air
