Laurie - I see what you say about the small flat and needing acrylics.
That said I have found that the AK enamel washes dont have too much smell and you can use their oderless thinner with them. Because of their nature they dry slower and you dont get the problem with drying on the tip of the airbrush. I have certainly found no real issues with them for smell but would wear a mask when actually spraying. You could also get one of the small spray booths that do not need venting such as I use. Taken together you might find there are no issues.
