I got my grandson PJ an A/B set up at home a few weeks ago. He's got a H&S Ultra A/B which is a nice enough bit of kit. A week after he started using it, he brought it to me saying it wasn't spraying properly. On close examination he'd broken the tip of the nozzle by forcing the needle too hard against it. I got him a replacement and got things working again.
Yesterday, he brought it back with some problems which I fear may be terminal.
Firstly, the paint cup no longer fits tightly into the body of the A/B. In fact it wobbles about and falls out with the slightest touch. I suspect he's been heavy handed again and I cant think of a fix for it. Any suggestions? Would a couple of turns of PTFE tape do the trick?
Secondly, he told me the trigger just 'fell out' one day when he was cleaning it, so I thought he'd not tightened the trigger retaining nut tightly enough, so that was an easy fix.
Finally, he gets air bubbles around the trigger mechanism when spraying. I noticed there was no friction when pushing the needle through the area where the rear seal should be. I suspected that the rear seal had failed so I tried to remove it and check it for damage.
I have one of those seal removal tools, but when I tried to remove the seal, I couldn't get the end of the tool to engage with the seal locking cap. Is there any way the seal and locking cap could have come loose and fallen out if he'd been fiddling around with it? He doesn't have that special gadget used to remove the seal.
Should these problems actually be terminal, can anyone recommend a bomb-proof A/B, bearing in mind that PJ is clumsy enough to break ball bearings!
