Clean-up after SMS paints
  • Flip
    • Jul 2022
    • 257
    • John
    • Speyside
    Hi guys,
    Just doing some spoon testing and going to try the SMS paints I've had for a bit. In particular PL15 (Red Oxide)
    Just wondering what folks use to clean down the AB after use.
    I've got MLT and Tamiya lacquer thinners - would prefer not to have another proprietary one if (say) MLT will do.
    Regards,
    • 18869
    I’ve used MLT to clean the airbrush for the SMS I have used. Tamiya lacquer thinners would probably work as well but I don’t have any so can’t say for sure.
      • 15598
      I do as Tim does. I do finish with a spray through of Premi Air Liquid Reamer though.
      • Nicko
        • Apr 2019
        • 1350
        • Nick
        • East Anglia
        I think MLT is a bit too good for cleaning, especially as it sometimes becomes unavailable. It's also pretty expensive. I use cheap cellulose thinners which will clean up after pretty much any paint. And it costs about the same for 5 litres as 400ml of MLT. After the swill out and blow through with the cellulose, I just run through a bit of the thinner for the next lot of paint and it's usually MLT....
        Nick
        • Flip
          • Jul 2022
          • 257
          • John
          • Speyside
          Thanks chaps...I'll give it a go
          Appreciate your input ?
          • Gern
            • 9201
            Nick
            Does that have any effect on the seals in your A/B? I have used cellulose thinners on bits which have no seals, but I've had issues with seals in the past so I'm reluctant to go with it.
            • Nicko
              Nicko commented
              Editing a comment
              They still seem to be going strong. H&S and Ultimate Apex.....
              Nick
            • 18869
            Depends on your airbrush I think Dave. The better quality ones have seals that are impervious to any solvent, and are sold as such. Certainly my Iwatta is. I’ve used cellulose thinners through it with no issues. I tend to use MLT because it smells a little less.
            • Nicko
              • Apr 2019
              • 1350
              • Nick
              • East Anglia
              With you on that last point Tim. Respirator, extractor and down the bottom of the garden in the workshop for that stuff.
              Nick
