Purchasing a new airbrush kit
    Hi there,
    I've just joined the forum as I'm looking for some advice regarding the purchase of an airbrush kit. I see there already a few threads on this topic so apologies for adding to them.
    I have a Tamiya 1/16 tank to build and paint. Other than rattle cans painting RC bodies I've always shied away from actual painting. However, I really would like to do this tank myself. I also have a couple of static cars and a few OO locos that might get a little weathering along the way.
    I've largely decided on this to get me going.
    http://www.ebay.co.uk/itm/TC88T-Airbrush-Compressor-2-Switches-3-L-ROYAL-130-133-Airbrush-Not-AS-186-/331227372139
    I noticed someone here made mention of putting beeswax on the threads when rebuilding? Is that due to poor tolerance in the threads?
    Appreciate any help/advice
    Edward you are asking a big question.
    Most important is the airbrush as this is going to give the finish. The compressor just supplies the air to make the airbrush work.
    On the compressor virtually all are from China unless you want to pay approx £150 upwards. These China types are very good provided you get a good one ie they all vary within the same model. Best is to get one with a holding tank as the air to the airbrush is then more or less a constant pressure. With out an air tank the flow of air can be very slightly stuttered.
    Airbrush buy the best you can. The type bundled with the compressor are not well engineered compared to Harder and Steenbeck and Iwata. All those through out the range of those two are good products and you will get good results.
    Just a warning. Iwata import into their range Neo. There are numerous comments about them some good some not. All the other Iwata range are manufactured by Iwata.
    Best to come back with what ever you have come to a conclusion on to get final advice before departing with the lolly. Also the size of needle/nozzle and the paint you intend to use in your model work.
      If I were you mate, I would go for the Iwata Eclipse HP-CS Airbrush. Pricey, but worth it. That airbrush has no warranty, definitely no spare parts, and I will guarantee you will have to be chucking it out after a year. The Iwata Eclipse and revolutions last for ages if you give them the right treatment
      • aaron
        • Oct 2011
        • 2019
        I advise to start with a duel action gravity feed airbrush no matter what brand.
        • aaron
          • Oct 2011
          • 2019
          Edward I got this one 2 days ago for £15, Nzd $30 delivered. Some will scoff because there's is no recognizable name but it comes with 0.2,0.3 and 0.5 needles and tips. Perfect for a beginner.
          [ATTACH]104547.IPB[/ATTACH]
          I know there is merit in buying well established named tools but if looked after the cheap option can still be successful.
            Careful here as we do not know what type of paint is being used. Plus even if water based some of the airbrush cleaners will eat there way through Airbrush seals unless they are produced to resist the chemicals used.
              Whilst it's quite possible to spend £120 or so on an H & S airbrush, if one were to buy a similar type to Aaron's you'd get 8 of them for the cost of the H & S .... effectively 8 years of airbrushing!
              I use one that cost £13.50, with hot solvents going through it all the time - hardly ever a blockage & no damage to seals.
              • Richi72
                • Sep 2013
                • 1100
                For a beginner, with no experience at all I would go with a cheap airbrush to get a feeling for it.
                As for the compressor one with a reservoir is the right choice.
                As you gather experience you can change the airbrush to the more expensive ones.
                I own an Aztek 470 for about 14 years now, never had any problems with it, but I have some cheap Asian Airbrushes too, and I use them allot with no problems yet and the oldest one (5 years) costed me € 17,00 and still use it.
                Cheers Richi
                  I bought this one last year, not used it a great deal, but, as a beginner has done all I need so far. http://www.rdgtools.co.uk/acatalog/AIRBRUSH-COMPRESSOR--WITH-TANK--AND-2-DOUBLE-ACTION-AIRBRUSHES-769080.html
                    this no name china airbrushes are low cost but at the end they are chinese garbage :/ i started with a chineese 130 model AB (you are ordering 133 model) it was good at the begining but after 6 months just "pah! garbage". you have to use it carefully, cleaning is little bit hard, it has spitting problems alot.
                    now i am using paasche talon, it is way better than this ABs. i ordered it from USA via amazon, total cost was 75$. the feeling, after using noname AB, is like " hell yeah! i am using AB"
                    that is my personal comment
                    Safak
                      My advice, for what it's worth, is, if you can get to a model exhibition with vendors in attendance, find a stand selling airbrushes, and see if you can handle some, and get a feel of them.
                      I have large hands, so Badger brushes feel too small and difficult to control, so I now have a (25 year old) Paasche VLS, which is solid and heavy and feels right in my hand. Your experience might (and probably will) differ completely..
                      Also remember that a (seemingly complicated, and fairly expensive) double-action airbrush can usually be adapted to single-action use, until you gain experience, you can't go the other way with a single-action brush.
                      Edgar
                        I would suggest an IWATA but I'd go for the Neo it is only £ 45.00 and works superb.
                        scott
                          To start you can get delivered on Ebay a compressor for £66 with a tank. The compressors are all the same in the under a £100 coming from the same Chinese factory. Only difference is they are branded and in the sellers livery.
                          Which puts the airbrush bundled with your package Edward at £30.
                          John in the shop has the Neo on sale at £34:88. Or if you can go further Edward an Eclipse at just over the £100 mark. Both have .35 needle/nozzles which are perfect for model paint types.
                          Although not as good as an Eclipse I am sure you will have more of a guaranty of quality with the Neo than the one bundled with the Compressor. The Airbrush in the bundle does not give the needle/nozzle size but you need especially for starting out a .35 needle size .
                          If by chance which I would say is slim you do not get on with airbrushing then the Eclipse would market well on Ebay. Neo not so good and the bundled one very poor.
                            True mate. That's why I like using the Iwata Eclipse.... Teflon seals
                              I completely agree mate. However, I sold my Neo for a very good price when I bought my eclipse. Basically, if it is an Iwata, or backed by Iwata, people are more likely to buy it than a no brand airbrush.
