First Robert I would try using a different colour to see if that works OK. If it does then the problem is the paint.
Model Air is made specially for airbrushing. But a lot depends on what you want to do with it and what size needle nozzle you are working with. .4 nozzle you can brush un thinned very well. .35 getting close to need thinning. Below that thin using Vallejo thinners. For the first coat I thin 25% second coat full on. As Steve has mentioned use the new Vallejo Flow Improver. Not had success using a .2 needle/nozzle but with flow improver it has been a revelation.
Normally with Model Air not had a problem just a quick shake and that is it. Yellows take the top off and stir as the ground stuff sinks to the bottom.
Iwata Neo is marketed under Iwata but is manufactured out of the Iwata empire. There are many who have no problems but some who have a lot of problems with Neo.
On the matter of enamels well these people just live in the ice age. Sad but I have no doubt in time they will realise the error of their ways. But we must feel for them as they are a dying breed (mostly due to the fumes of enamel :P ) and will become extinct before this century gets much older. We must of course impress upon them that there is a way out. Switch to Vallejo Paint and they will live a long and gloriously happy life.
Laurie Vallejo
PS on the PSI depends on what you are doing. A large area 18PSI. Effects shading etc 8PSI
Laurie Vallejo
