Spray Booth
    Spray Booth
    Any ideas of where to buy and what to buy. Obviouy it needs to be big enough to work on 1/35 scale and also I would like to vent it to outside. Seem to remember Laurie joining two side by side but cant find it in the threads now.
    Cheers guys
  • John
    • Mar 2004
    • 4634
    • John
    • Halifax
    I stock the AB500 spray booth, it should suit your needs
    www.scalemodelshop.co.uk
    • Adrian "Marvel" Reynolds
      • Apr 2012
      • 3008
      This is the one I use, you can if you wish also join two together for larger projects
      http://www.ebay.co.uk/itm/Portable-airbrushing-spray-booth-extractor-E420-with-extraction-kit-/120891551071?pt=LH_DefaultDomain_3&hash=item1c25b2 ad5f
      Adrian
      • eddiesolo
        • Jul 2013
        • 11193
        I have one that is similar to the one John is selling, mine has a built in LED light. Very simple to use and the hose can be attached through a wall or vented via an open window.
        The figure and model shown are 1/24 scale and I managed.
        Si
        [ATTACH]111683.IPB[/ATTACH]
        [ATTACH]111684.IPB[/ATTACH]
        [ATTACH]111685.IPB[/ATTACH]
        [ATTACH]111686.IPB[/ATTACH]
        • John
          • Mar 2004
          • 4634
          • John
          • Halifax
          Same with the AB500
            • Apr 2012
            • 3008
            Same with the AB500
            But £17 more With no hose
            • John
              • Mar 2004
              • 4634
              • John
              • Halifax
              I do price match
                I`ve got the Expo one John stocks with the hose , its fine size wise for 1/35 scale and superb if spraying acrylics or water based paints but struggles with solvent or enamel spraying in my opinion , its big bucks if you want a spray booth that can cope with spraying solvents , if you only spray acrylics its great you can even hoover the filter every now and then and it works like new again .
                  Cheers guys
                  Yes Alan the one John stocks is the one I have by 2. I keep all the cleaner, paints etc in the joied booths. keeps all the mess in one place.
                  Also you have two fans. Coupled up the two hose with a B & Q connector.
                  Makes a nice set up if you have the space.
                    I have the one John sells (to my shame I bought it from elsewhere before I discovered this forum). I worked out that it was not big enough to house a 1/72 Lancaster bomber fully assembled (it is a big beast even at that scale) but no-one would need to paint the entire model in one go. With two side-by-side you would get a spacious booth.
                    I vent mine through the window, which works well (it comes with a fishtail end which can be wedged through a slightly open window. Although I use acrylics I have never had significant smells indoors. It has sufficient draft to suck fumes to the back and out to the hose.
                      I have the led one, I would opt for johns 2 booth though. Better than eBay customer support and really, I can see me needing to re-buy or modify mine in the future for bigger kits. It's perfect for 1/24 cars though...
