Just wanted to share my views and thoughts on my new Iwata Eclipse HP- CS. It arrived through the post from John at SMS.
I took it to pieces to see what was what and reassembled perfectly. The weight is a little heavy for an airbrush compared some other makes, it is a good weight though.
I agree with other comments on smaller intricate detail brushes that may be smaller and lighter, but for general use I believe this airbrush can do a great deal.
I then popped in a few drops of Vallejo thinners and few drops of a Vallejo paint. Putting y thumb over the end cap I back aired to mix the paint and thinners. Giving a quick stir with a cut down cotton bud I believe the airbrush was ready for its first spray.
Close on a piece of kitchen towel I could get fine lines and further away a more general spray. I also tried the Luftwaffe mottle pattern and this was easily achieved with the A/b. Taking an old piece of plastic wing ( 1/48 ) from my spares drawer I found that presiding was easily achieved and control over the air adequate.
I was spraying at 12/15 psi and this seemed to be adequate, possibly this could be dropped lower if need be.
I still have a few armour models in my stash and when it comes to highlights and definition lines I believe I should have no difficulty.
Now tio cleaning
With the main cup now empty I put in cup few drops of a/b cleaner and few drops of distilled water, again thumb over the end I back aired to clean the nozzle of paint.
Flushing the air brush with Luke warm water and using cotton buds ( q tips ) the brush was cleaned and ready to go for next paint.
The Iwata Eclipse came with small tube of lubricant ( have lots of that anyways from other a/b and a small spanner to remove the needle protector
Overall conclusion
This airbrush is a good mainstay for any modeller ( yes there are equivelant a/b out there and better more expensive examples, but through choice I believe the Iwata Eclipse is a very good Airbrush for the modeller
Kind regards
Robert
