I use a Badger 150 I bought this before I had any real idea of what was available. I have a couple of questions. My airbrush came with three different needles and crowns which have marked on two of them F and B, the third has no mark. Am I to assume then that these marks refer to Fine and Broad respectively. Please forgive my ignorance, but I was under the impression that it was how far I pull the trigger back and the distance from the item being sprayed that determined the size of line or area being sprayed.
Also just what does the crown cap do?
This airbrush has certain limitations in that it seems to have been designed for a glass jar to attach to it in order to provide a reservoir for the paint however, it also came supplied with a small colour cup but it is almost impossible to prevent paint from spilling out as you get involved in spraying you model items!
Think I may need to invest in a new one after xmas!
