compressed air??
    compressed air??
    Forgive my stupidness if this is insane.....
    Talking to my neighbour (who dosent model) I said I was getting an airbrush for modelling and how expensive compressors are... He immediatly walked to his garage and said.... "I've got an EMPTY pressure tank (like a calorgas canister), I could fill it up from my compressor. if you buy a regulator you can have it and I'll refill it free anytime"
    Has anyone ever heard or used this method?? would it work??
  • PaulTRose
    • Jun 2013
    • 6459
    • Tattooine
    ive heard of it done with scuba tanks.......make sure you have a moisture trap as well as a pressure regulator....and all the thread sizes are compatable
    Per Ardua
    • PaulTRose
      • Jun 2013
      • 6459
      • Tattooine
      id also make sure that canister can hold the pressure you re going to need.....no idea what calor gas pressure is
      Per Ardua
        Ok that sounds promising. Let me do some research then regarding pressures and such.
        Thank you.
          A Calor gas tank will easily hold more than enough pressure for airbrushing. A chap at my local model club uses one. People have even used tyres as a reservoir for compressed air!
          As Paul said, a moisture trap is essential & a decent regulator will save money in the long run. The ones most usually fitted to modelling compressors are prone to leaking due to cheap parts.
            I did wonder about a tyre (got loads of them knocking about) and can refill it from the car pump thing.... Was thinking the gas bottle although empty might still have fumes in it.. Don't want to be getting all high or anything
            That's a completely different hobby
              What kind of pressure will the airbrush take if I use the tyre method? 40/50 psi?
              Or do I still get a regulator for that method?
              Would this kind of thing be correct?
              http://www.google.co.uk/search?q=moisture+trap+and+regulator&tbs=vw:l&tbm= shop&prmd=sivn&ei=g-SpVsq4KMKOa8O9gbAL&start=20&sa=N&biw=527&bih=295&d pr=1.5
                I Will buy a propper compressor at some point but just want to get started. Bought a good airbrush (£100 worth) so don't want to be blowing it up
                  Any residual gas fumes are more likely to get you blown up than high Stuart! Just flush the tank with air a couple of times to clear it out.
                  Tyres have one main drawback - a lack of capacity. You'll be forever filling it up if you don't have your own industrial compressor. Also the risk of contamination is higher - dirt, dust, rubber flakes don't make good bedfellows when spraying.
                  Most tyres in good nick will take 50 PSI. But you'll always need a pressure regulator, whichever route you take for the air reservoir.
                  Also, it's worth bearing in mind that filling a tank tyre is similar to using a can of compressed air. You've got to keep an eye on what's remaining, because it's quite easy to keep spraying without knowing that the pressure is almost gone. That can cause all kinds of problems, most of which will ruin a paint job!
                    Ok I see. Maybe I'll just spend the £75 and be done with it. First model or two I'm gonna grab some car spray paint. Don't want to be breaking a brand new airbrush.
                      My brother in the past has done exactly the same for me and it works really well! I do now however own a airbrush compressor as they are smaller.
                        Thanks Mark... I'm now re thinking the tank.... As I can get it refilled free all I'd need is a good regulator/airfilter combo which I could get for around 10/15 quid.... Fumes are my worry as I have small kids tho. Let me see if he fills and empties it a couple of times if I can smell anything
                          The problem is Stuart if its an old gas bottle there will be liquid gas in it for quite a while! Mine was an old air compressor tank so I didn't have to worry about that side of it but in the end a £50 compressor from on here has been running great and does all that I need it to do and as said earlier its smaller and lighter
                            Yep think your right. A basic compressors the way to go. Gonna bite the bullet and get one.... Worth it in the long run... Spray cans and brush paint in the mean time.
                              This is the one I got mate! Nothing fancy but light, quiet, small and does all the jobs a compressor should do http://www.scalemodelshop.co.uk/mini...or-as-18a.html
