Look for the video by ism on how to clean an airbrush with like 2ml of cleaner. It will show you where you are going wrong. I have an h&s infinity and it's so easy to clean but I still got tips from that video on YouTube.
If air is getting into the cup maybe you had a bad seal from factory. Finger tight with no tape or wax or anything. If it's not right send for a new one. Don't mess about trying to seal it a different way from how it should have worked out of the box.
These brushes are high precision instruments and are very easy to clean with only a tiny amount of cleaner. They work nearly flawlessly if set up right.
I may be coming off bad which is not my intention but I'm 100% sure that you will get better results than with a crappy cheap ab!
