A couple of years ago I used Tamiya gloss lacquer (spray can) to produce a very good mirror finish using my Harder and Steenbeck CR+ (0.4 mm needle). The thinner/cleaner is Cellulose Thinners. I used lots of this thinners to very thoroughly clean the AB (including use of an ultrasonic cleaner) and did not use it for some months. I then tried to spray Vallejo Model Air through it but had constant blockages, sometimes after only a few seconds. I had in the end to replace the needle and the nozzle. I mentioned this on this forum but no-one could confirm this. I have just been viewing the ISM (International Scale Modeller Thinners Guide:
and the speaker strongly warned never to use the same airbrush with Cellulose Thinners or any paint which has that as its thinner, and then, for a later airbrushing session, either Vallejo or Xtracrylic paint. The result will be mush that will not be cleaned.
This seems to be confirmation of this. I certainly will never do that again. Be warned.
