Acrylic Primer for Airbrushing
    Not really related to airbrushing primer but as a test I today bought 2 rattle cans of Tamiya Primer, 1 Standard grey and 1 Fine grey, to go along with my Halfords Plastic Grey Primer.
    I sprayed 3 different pieces of black plasticard to see the difference between the primers.
    What I found was the Halfords primer was a slightly darker grey, went on quite heavy as I covered the area in 3 passes, and dried to a nice very fine textured sheen.
    The Tamiya standard primer went on very similar to the halfords brand but has a lighter shade and a slightly smoother finish.
    The Tamiya Fine primer was a little more opaque so required a few more passes to cover the area, I'd say from that you have a little more control on the amount of paint your applying. It dried the same as the other Tamiya primer and gives a really smooth texture free finish.
    When it comes to strength, I let all free dry for 2-3 hours and attempted enthusiastically to scratch the top surface with my nail. I couldn't get any of them to budge, really adhered well.
    Atb, Colin.
      My 2 cents. Having used the Tamiya and Humbrol spray primers, I would highly recommend the Halfords standard primer against the other two. As far as quality and application go I can see no distinguishable difference, especially after flatting with wet'n'dry or micro-mesh. Litre for litre, the 'model specific' primers work out approximately twice the price of the Halfords.
      Of course there is a lot of power behind the propellant, as it's designed to spray car panels, not models! I invariably decant mine for use in my airbrush. This gives me control over the spray and reduces waste no end. I can easily at least 2 1/72 kits with less than 1/5 of a can (about £1.50 worth). If you're going to attempt this, be sure to check a tutorial (several on YouTube) because, as I found to my cost, if you do it wrong you can end up with a face full of paint!
      I use both grey and white. Nothing shows up faults in the surface quite like grey primer! Once any faults are rectified, 2 or 3 coats of white leaves your model ready for the top coat.
      John.
        Mr color stuff seems OK too. You can get it different particle sizes for different jobs. The advantage over the Halfords stuff would be that if you make a mess of it you can clean it off with IPA without destroying the plastic. Some of the thicker stuff can be used as a filler for fine lines if you just brush it on and wipe off the excess.
