H&S Ultra
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4596
    • Bob
    • London
    H&S Ultra
    Hi guys,
    I'm thinking about upgrading from my ancient Devilbiss Sprite A/B and have been looking at the H&S Ultra.
    I've read a number of pro and con threads on this a/b and wanted to ask people who have them what they thought of them after having them for a while. I would probably get the 2 in 1 kit.
    The alternative would be the Evolution 2 in 1, but at £50 extra I'm not sure if it's worth it for the relatively small amount of use it will get.
    Help!
    Si vis pacem, para bellum.
  • col68
    • 1505
    Hi Bob I can't comment on the ultra but I bought an evolution from john in November and I think its the best airbrush I've ever used. If you can justify the price you won't be disappointed
    • John
      • Mar 2004
      • 4631
      • John
      • Halifax
      If people have problems with the Ultra it's usually the seals, they don't come with them, I have spares that I give to customers if they have problems and that generally fixes any issues, all in all it's a good airbrush.
      www.scalemodelshop.co.uk
        I totally agree with Colin. I got the Evolution 2 in 1 and it is superb. I have long been a champion of the budget airbrush and I still believe that if cannot afford a top end brush then go with what you can afford as you will still achieve good results and learn how to use one. I only bought the Evolution because I was in a situation where I could splash out on it.
        Getting a higher end brush will not make you a better airbrusher (?) but it will give you ease of cleaning, consistency in how it works and tighter quality control which all adds up to giving you the chance to take your skill forward.
        On tip I would say that if you get a H&S, whichever model, get yourself the cleaning and maintenance tool set. The reamer is designed to work with their nozzles and the special screwdriver makes changing the seals deep inside a lot, lot easier.
        I had issues with the H&S budget brush, the Ultra, I still say it was the worst brush I have owned although I know people have used it to good effect and it was well reviewed in many sources but the Evolution has been an absolute dream to work with. Having the two needle sets, .2 and .4 and the two sizes of paint cup really add to the deal. The Ultra has a push in cup which dislodges easier than it should. The Evolution and above have screw in cups with proper seals.
        I have never once regretted the Evolution and cleaning is so simple, it has become a pleasure rather than a chore.
          I have both the Ultra & the Infinity CR Plus. Both are excellent airbrushes. I also have & have been a long-term champion of budget airbrushes.
          The Ultra 2 in 1 is a great upgrade from the cheap Chinese ABs. I would list the advantages as follows:
          Overall engineering is excellent, you can feel the quality. Parts fit together in a way that cheap ABs just can't match.
          The trigger is very good. Whilst any airbrush won't necessarily make you any better, you'll get much more control & therefore confidence in its use.
          Cleaning is so much easier with an H&S. No mini spanners to fiddle with or worries about over-tightening the nozzle. Everything is really easy to access with no awkward nooks or crannies.
          HTH
          • Mr Bowcat
            SMF OG
            • Dec 2016
            • 4596
            • Bob
            • London
            Thanks for the advice guys. Looking at the Evolution, the silverline model is about a fiver more. Is it worth it?
            • col68
              • 1505
              That's the airbrush I use Bob its excellent As Patrick said easy to clean solvent resistant seals and you can set the distance the needle opens for paint control
              • Mr Bowcat
                SMF OG
                • Dec 2016
                • 4596
                • Bob
                • London
                I've just realised there's no Council Tax payment due next month,so things are looking good for an Evolution.
                I'm not sure if I will need a new airline as I'm not sure what thread the line for my Sprite is. Something I read suggests that Devilbiss didn't use a standard 1/8 thread??
                  I'd be surprised if any airbrush uses anything other than a 1/8 thread. That's been the standard since the 1920s I believe. But adapters are easy enough to find.
                  The Silverline has a paint control doodah... whatever that is! It's probably worth having for only £5 more, but I hardly ever use the fancy features on my Infinity.
                  • Mr Bowcat
                    SMF OG
                    • Dec 2016
                    • 4596
                    • Bob
                    • London
                    Thanks again for all the advice guys. It's pay day tomorrow and my minds made up.
                    • PhilJ
                      • May 2015
                      • 1145
                      Yep I have a evolution silver line, seems like you can't go wrong with a h&s to be fair.
                      One thing I would say is one of the guys on here pointed back to a Iwata hp-ch and let me tell you if you can stretch to one of those you will not be disappointed. Now owning both myself I can say that the iwata is on another level.
                        £70+ difference between the Iwata & an H&S Silverline 2 in 1 though Phil!
                          I also have a H&S Evolution 2in1. For me I cant find fault with it. It really is superb quality. As for cleaning, its very easy.
                          My AB before this was a Badger 105 which I now only use for primer and laquer.
                          Cheers Alan
                            just got my H&S evolution silver line , absolutely superb , fantastic airbrush , I'm like alan had an iawata neo , nice brush , but it only gets used for priming , dull coats
                              Just a word of warning, the Ultra is no De Vilbis. I'm sure the more expensive ones are great, but the Ultra is very much built to a price. It's ok, but no cigar. I have stopped using mine in favour of a single action one from John.
                              I wrote a fairly comprehensive piece on it in "airbrushing" section. I've not looked back since getting it.
