Spraying Humbrol matt cote
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4600
    • Bob
    • London
    Hi guys,
    Quick question, am I OK to thin Humbrol matt cote with White Spirit? I don't have their own thinners but have been using WS to clean brushes and it seems to mix OK. Just wanted to check before I ruin 5 weeks work.
    B
    Si vis pacem, para bellum.
    From what I read online people do thin it with white spirit when brush painting but use Cellulose Thinners or Humbrol thinners when airbrushing if its the Humbrol Enamels you use, but people also mention not to over thin with Cellulose Thinners as it could damage the plastics.
      That's what I use Bob, and I've never had any problems.
      Just be sure to stir it very very well before use. I recommend using a powered stirrer - I made my own from a nasal hair trimmer from Poundland.
        Originally posted by Morpheus
        From what I read online people do thin it with white spirit when brush painting but use Cellulose Thinners when airbrushing if its the Humbrol Enamels you use.
        Just to prevent any misconceptions, although Humbrol Matt coat might well thin with cellulose thinners, I wouldn't recommend it. White spirit works both for brushing & airbrushing.
        • Mr Bowcat
          SMF OG
          • Dec 2016
          • 4600
          • Bob
          • London
          Cheers Dave, and thank you Patrick, just the answer I was looking for.
          • Mr Bowcat
            SMF OG
            • Dec 2016
            • 4600
            • Bob
            • London
            Patrick, how long do you normally wait between coats, and how many coats do you apply?
            B
            • Thorbrand
              • Dec 2016
              • 335
              Personally for thinning i use low odour white spirit as its less abrasive
                B
                I guess that depends on how matt I want the finished model to look. Generally with armour I do 2 coats, applied roughly 6 hours apart.
                Personally I would go by eye, and once you're happy with the effect leave it at that.
                • Mr Bowcat
                  SMF OG
                  • Dec 2016
                  • 4600
                  • Bob
                  • London
                  Fantastic, Cheers Patrick.
