Spraying Xtracrylix gloss varnish
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4596
    • Bob
    • London
    Hey guys,
    Just wondering if anyone had any experience of spraying this stuff? The bottle recommends thinning 10-15% with water but it seems very gloopy still and I'm unsure what PSI to run the compressor at? I'm using a .4 needle.
    B
    Si vis pacem, para bellum.
    Bob, I've used both the gloss and Matt and mixed with water as recommended.
    I spray at a little over 20 psi and even though it appears gloopy it sprays fine.
    I have found it drys quickly in the airbrush if left for a few minutes so clean it as soon as you finished.
    Don't be to liberal with your application especially if using the Matt as it can leave a blue looking bloom to the finish.
    • Mr Bowcat
      SMF OG
      • Dec 2016
      • 4596
      • Bob
      • London
      Thanks for that. What sort of ratio do you thin to.
        I would go for 15% water but a little more shouldnt harm.
        • Mr Bowcat
          SMF OG
          • Dec 2016
          • 4596
          • Bob
          • London
          Excellent, cheers.
