W&S Galeria varnish
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4600
    • Bob
    • London
    W&S Galeria varnish
    Hi guys,
    I bought some Winsor & Newton varnish to try, just wondering if it needs thinning to airbrush? If yes, how much and with what?
    B
    Si vis pacem, para bellum.
  • yak face
    • Jun 2009
    • 13840
    • Tony
    Hi bob , i use the windsor and newton galeria matt acrylic for my final matt coat and usually thin it a little with distilled water before spraying. I give it a few light coats and leave it for 24 hours before handling, hope this helps , cheers tony
    • Mr Bowcat
      SMF OG
      • Dec 2016
      • 4600
      • Bob
      • London
      Cheers Tony, any idea on what sort of ratio or is it just by eye?
      • yak face
        • Jun 2009
        • 13840
        • Tony
        Its just a 'mix it till it looks runny enough' method! One thing though once youve added some water give it a very good stirring , not too vigorously as it can froth up a bit and you dont want loads of bubbles. If its too runny it will spray fine but can separate and go streaky on the model , its just a case of practising on scrap till you get the hang of it, cheers tony
        • Mr Bowcat
          SMF OG
          • Dec 2016
          • 4600
          • Bob
          • London
          Cheers Tony, appreciate the advice.
          • BarryW
            • Jul 2011
            • 6012
            I tried it on my 1/32 MkXVI Tamiya Spitfire and thinned it with water, about 30% for spraying. I found that it worked well but did take a long time to dry and even longer to cure to a hard finish. Much longer than products like AKI Ultra Matt.
            • Mr Bowcat
              SMF OG
              • Dec 2016
              • 4600
              • Bob
              • London
              Thanks for that Barry.
                I use their matt, and thin 2 parts varnish to 1 of tap water. It would probably go through the airbrush thicker than that, but I find the matt varnish only needs the thinnest misting of a coat to do the job. I love the stuff. Haven't had any problems with slow drying, but would always leave it 24 hours anyway.
                • Mr Bowcat
                  SMF OG
                  • Dec 2016
                  • 4600
                  • Bob
                  • London
                  Cheers Doug.
