Thinning tamiya paint's for airbrushing
  • peterairfix
    • Jul 2012
    • 11074
    Can any one tell me what the ratio for tinning tamiya paints for airbrushing and what's the best ready to use paint's for airbrushing.
    You're help will be much appreciated.
  • Mr Bowcat
    SMF OG
    • Dec 2016
    • 4600
    • Bob
    • London
    I use 2:1 paint to Tamiya thinner, sprayed at 20 psi.
    Si vis pacem, para bellum.
      Yep I'd go with Bob's ratio, although I spray at 25-30 PSI. Tamiya paint goes on best with a wet coat & keep the nozzle close or you'll risk getting a orange peel effect.
      Vallejo Model Air, AK Interactive, Ammo by Mig are all good airbrush ready paints. Some people still thin them a touch and/or use a flow improver or retarder to avoid clogging.
      • col68
        • 1505
        Peter check out Andy's hobby's on YouTube his method for thinning tamiya paints.
        It works brilliant. As Patrick mentioned i find 25-30 psi about right but since your on canned air you may need to adjust your regulator as you get down the tin
        HTH
          2:1 to 3:1 for me roughly
          • BarryW
            • Jul 2011
            • 6010
            I agree with Patrick about AK Interactive, Vallejo Model Air and MIG for spraying. I use these. But if you do not mind a paint that has a lot of fumes then the MRP paint range are just about the best you can get for an airbrush, but you do need an extractor fan. These paints are more like ink than paint and are gaining a large following.
