AS 189 compressor slow leak
    Hi everyone,
    I've been away from modelling for a year, but I recently got the urge back and started a nice little Tamiya BF109. My compressor is an AS189, that I bought maybe 2yrs ago from the shop, and it's had only light use.
    When I started it up after a year of being stored in the box in my wardrobe, I noticed the sound of air escaping, and the motor kicks in much more frequently to keep pace with the leak. I traced it to the non return valve:
    [ATTACH]295233[/ATTACH]
    A bit of googling points to the solenoid valve, which costs about £10. Any other ideas? It was working perfectly before. Is there a rubber diaphragm or similar that may be dried out?
    Thanks for any suggestions.
    Tony
  • stillp
    • 8086
    • Pete
    • Rugby
    There's an exploded view at http://www.airbrush-fengda.co.uk/upl...pare-parts.jpg
      Originally posted by stillp
      Thanks Pete, I'm hoping someone has had a similar problem and managed to fix it.
      • stillp
        • 8086
        • Pete
        • Rugby
        If it's knackered, try a squirt of WD40 in it, you've nothing to lose!
        • jameshoughton1997!!!!
          • Oct 2015
          • 136
          On mine i had a slow leak and i found that when id moved it the nut on the tube connecting the compressor to the tank was lose messed with it for 10 amd it stoped just a sugestion
          • colin m
            • 8740
            • Colin
            • Stafford, UK
            The same solenoid failed on mine some years ago. Changed it (easy job) and all has been well since then.
              HI Colin. Were the symptoms the same when the solenoid failed? I'm not worried about fixing it myself, I just want to make sure I get the right part.
              • John
                • Mar 2004
                • 4633
                • John
                • Halifax
                If it is the solenoid, I have a spare one I will let you have at a good price.
                www.scalemodelshop.co.uk
                  Thanks John. Let me know how much please.
                  • colin m
                    • 8740
                    • Colin
                    • Stafford, UK
                    It was a while ago, but yes, the air was escaping out of the back. I think you can put your finger over it and feel the air escaping.
                      Thanks Colin. Yes, that's it exactly.
                        Thanks to John at the shop for supplying the spare part at a good price. The compressor works fine again.
                          • 18264
                          Glad that you got it sorted, I find that a lot of leaks can be resolved with either silicon spray, like the stuff you put on car door seals, and PTFT tape.
                          Silicon spray on rubber gaskets and PTFT tape to re-tighten connections.
