Question
  • scottie3158
    • 14197
    • Holbeach
    Question
    Hi all,
    I have a question for you more experienced people. What would cause the air brush to stop spraying mid flow, but on releasing the trigger it sprays a small amount.
    Any pointers would be very welcome.
    Scottie
  • Steve O
    • Dec 2017
    • 327
    If the needle chuck nut is tight and not slipping chances are partial nozzle blockages crud or bits of skin etc, not much else i can think of.
    Steve.
    • scottie3158
      • 14197
      • Holbeach
      Thanks Steve,
      I will check that out.
      • Mr Bowcat
        SMF OG
        • Dec 2016
        • 4596
        • Bob
        • London
        Agreed, blockage in the nozzle is probably the most likely cause.
        Si vis pacem, para bellum.
        • scottie3158
          • 14197
          • Holbeach
          Thanks Bob,
            • 18883
            Hi guys, are we sure this isn’t tip drying, with the dried paint block being circumvented when the needle closes and moves the tip forwards? Happens to me every time I use acrylics through an airbrush....what paint are you using Scottie?
            Tim
            • scottie3158
              • 14197
              • Holbeach
              Hi Tim,
              I use Vallejo acrylics most of the time. when I mix it is either to thick or comes out in large dropplets
              • JR
                • May 2015
                • 18273
                Hi Tim,
                Paul.
                I had the same problem , got some Vallejo retarder from John at the shop.
                I just add a couple of drops into the paint as per the instructions, mix and pour into the paint pot on the ab. Seems to have worked , even in this heat. Before I would have to clean the needle and the head. It would always be as Tim has said, a lump of crud would appear when I pushed the point of tool through the nozzle.
                John.
                • SimonT
                  • 2824
                  My solution to VJ spraying problems was to go back to Tamiya for spraying and just keep the VJ for brush - worked a treat :smiling:
                  • rtfoe
                    • 9065
                    Yup that worked for me as well.
                      • 18883
                      Make that three...Tamiya with Mr Colour levelling thinners, match made in heaven, sprays like silk....I’ve tried several brands of acrylic and had the same issue with all of them...need a good mask though.
                      Tim
                        • 15645
                        Hi Scottie
                        Another possibility is that the needle is slightly bent near the tip. Take out the needle and roll it on a flat surface and watch the tip. You will easily notice if the point is bent.
                          Just bash it against the bench!:smiling3: (My answer to everything).
                          • Si Benson
                            • 3572
                            That’s one of my tricks....I call it the ‘engineers tap’. Sometimes you’ll need an adjustment stick too!!
                            [ATTACH]310933[/ATTACH]
                            Si
                            • scottie3158
                              • 14197
                              • Holbeach
                              Thanks all,
                              For the replies. I'm not sure if the tool fine adjustment is big enough.
