Needle in and out - which way?
    I’ve read conflicting ideas about this. One is ‘out from the front in from the back’, others in and out from the back. Is there a right and wrong?
    Max
    • 22770
    I go out from the front and in from the back Max. It pulls the paint away from the inner workings.
      Max
      When cleaning push needle from the back so that it enters towards the nozzle. That way you are not drawing paint into the air brush. Re assembling again from the back towards the front.
        Hi Alan
        If you actually mean ‘so that it EXITS towards the nozzle’ then you appear to be agreeing with Ian, otherwise we already have conflicting ideas!?
          Hi Alan
          Yes exactly that. Cheers
            Cheers Alan
            • Mr Bowcat
              SMF OG
              • Dec 2016
              • 4596
              • Bob
              • London
              I always take out and put in from the front. Obvisouly taking it out means I'm not pushing paint back through the seal, and my theory is by putting it back from the front the brush will already have been fully cleaned and I'm not risking damaging the needle tip.
              Si vis pacem, para bellum.
                Originally posted by Mr Bowcat
                I always take out and put in from the front. Obvisouly taking it out means I'm not pushing paint back through the seal, and my theory is by putting it back from the front the brush will already have been fully cleaned and I'm not risking damaging the needle tip. :smiling3:
                Hi Bob,
                Yeah, one of the things I’d read was that you could damage the seals putting it in the front?
                Max
                • stillp
                  • 8086
                  • Pete
                  • Rugby
                  I'm with Bob, I remove and insert from the front.
                  • stillp
                    • 8086
                    • Pete
                    • Rugby
                    I think you're more likely to damage the seals if you catch them with the sharp end of the needle. Wouldn't do the needle much good either.
                      Okay, I can see that opinions vary on this! All I can say is, don’t fight boys and girls!
                      • PaulTRose
                        • Jun 2013
                        • 6453
                        • Tattooine
                        i have an Aztek.....i dont have this problem :smiling5::smiling5::smiling5::smiling5::smiling5: :smiling5:
                        Per Ardua
                          What’s an Aztec, apart from an extinct South American?
                          • stillp
                            • 8086
                            • Pete
                            • Rugby
                            Why's that then?
                            • PaulTRose
                              • Jun 2013
                              • 6453
                              • Tattooine
                              its an American airbrush........uses a totally different system......has interchangable nozzles for different sizes or applications......the needles are only an inch long......and in some sizes are plastic!
                              lots of people hate them and like to deride them, i think they are great............ive own everything from cheapo chinky air brushes to badger and iwata.....all have terminally let me down in one way or another
                              dont get me wrong, Azteks have their own problems but i like them
                              this is a nozzle assembly....about twice real size lol
                              Per Ardua
