Isopropyl & MRP paint
  • Remodel_Remake
    • Jan 2015
    • 17
    Hi Folks,
    Hoping I can probe your collective brains here, just got a few of the MRP paints to try & was told that 99% isopropyl alcohol was the best thing to clean out the airbrush with after spraying it.
    Now I’m a bit confused as to if you spray this at fully strength or mixing it down 50/50 with water & then use a cleaner?
    I do have a benchvent extractor & wear a face respirator, but atomising the full strength iso still worries me a little.
    Any help or guidance would be greatly appreciated .
    E
  • dave
    • Nov 2012
    • 1828
    • Brussels
    I use neat IPA to clean the airbrush with MRP paints. Works well for me, of all the paints I have used these seem the easiest to clean out of the airbrush
      I also use neat IPA ti clean my airbrush and find it works very well.
      • scottie3158
        • 14199
        • Holbeach
        IPA? and does it work with Vallejo ?
        • Remodel_Remake
          • Jan 2015
          • 17
          Thanks for the replies, so do you folks not dilute it down at all?
          Regarding Vallejo, pretty sure that isopropyl turns it into a nice jelly type material that’s a nightmare to deal with in the nooks & crannies ofthe brush.
          • Remodel_Remake
            • Jan 2015
            • 17
            Sorry my bad trying to do too many things at once & didn’t read your replies fully, I see you all use it neat.
            Will gave it a go & report back.
            Thanks again & apologies for not reading more carefully.
            • BigGreg
              • 2182
              Hey Paul
              IPA is for cleaning and YES it works, i use it all the time... :smiling::smiling::smiling::smiling:
              1. i paint vallejo 60/40-70/30 paint/water
              2. i clean 100% IPA
              3. i just put 4 drops of airbrush cleaner of Vallejo (a very little quantity will remain in the brush the vallejo cleaner is a tiny bit greaser) then i empty it
              hope it helps...
              • scottie3158
                • 14199
                • Holbeach
                Originally posted by BigGreg
                Hey Paul
                2. i clean 100% IPA
                hope it helps...
                Greg cheers for that.
                  I have just bought ipa from Darrant chemicals mention on this forum in another post. Also got some vms thinners for TMS.
                  • dave
                    • Nov 2012
                    • 1828
                    • Brussels
                    There was a great article on hyperscale a while back which tested a grid of paints and thinners/cleaners for compatibility.
                    The one I remember as it happened to me was Vallejo airbrush cleaner turns gunze-sangyo mr paint (the aqueous series) to a jelly.
