Airbrush/Compressor Combo Advice
    Does anyone know of a good airbrush/compressor combo that is between £0-£100? Any advice would be greatly appriciated.
  • JR
    • May 2015
    • 18273
    Isaac .
    [ATTACH]324591[/ATTACH]
    Not sure about the airbrush but this set comes from John's shop here on the forum.
    Think a lot of the guys have the compressor, I do and always done well .
    John is out of stock at the moment, but you can find these on the net as well . It comes in under the £ 100 mark.
    John.
      Thank you, John
      • JR
        • May 2015
        • 18273
        Your welcome, you didn't say where you hail from so hope its in the UK.
        John .
        • AlanG
          • 6296
          John .
          John as long as he's not from yorkshire then he'll be fine. Us yellow bellies have to be particular who we talk to :tongue-out3: lol
            We may have a problem here, I may or may not be from North Yorkshire.
            • John
              • Mar 2004
              • 4631
              • John
              • Halifax
              Isaac .
              John.
              I am out of stock of this airbrush but have others
              www.scalemodelshop.co.uk
                Thank you very much John, the first product link seems very good.
                • stillp
                  • 8086
                  • Pete
                  • Rugby
                  It is! Served me well for a while, although I've now upgraded the airbrush.
                    Isaac,
                    been using the AS186 for many years now - and recently bought a 0.2mm Airbrush from John at SMS.
                    Don't worry about the Yorkshire jibes, those who weren't born there are always jealous
                    • BarryW
                      • Jul 2011
                      • 6010
                      I used the AS186 for several years and it is a good compressor.
                      The packaged airbrushes are OK but I would recommend that you get a gravity fed a/b such as in the links John provides. A time may come when you decide to upgrade the airbrush though but these bundled ones are a good place to start.
                      • AlanG
                        • 6296
                        Only two good things about yorkshire. The M180 and A180 out of it lol :tongue-out3:
                        Just jesting with you lads
                        • boatman
                          • Nov 2018
                          • 14450
                          • christopher
                          • NORFOLK UK
                          Hi guys ive done a bit of airbrushing for the first time an I must admit I dint like how it turned out but looking at your model's on here im beginning to have a rethink about buying one. but out of the two that are mentioned above which is the best one ? chris
                            Chris,
                            I don't know about 'best', as I haven't owned both type of compressor, BUT I have owned an AS 186 since September 2013. It is reliable, portable, and quiet enough to be able to hold a conversation when running. The air tank gives a continuous steady flow at your set pressure. The cylinder head gets hot, but I've never had it cut out on overheating.
                            Airbrushing takes practice, finding the correct pressures, and the right ratio of mix for your style can only really be found by trying them out...................
                            • boatman
                              • Nov 2018
                              • 14450
                              • christopher
                              • NORFOLK UK
                              Ok cheers Dave i'll have a think about it chris
