Rough finish
    Rough finish
    Hi everyone.
    I'm back in the hobby after many years.
    I want to step up my quality work and need advice.
    I'm painting an aircraft using Vallejo air and their airbrush thinner.
    I am getting quite a rough surface which makes panel line weathering hard ( I do seal with clear)
    I am a bit impatient and might be applying the coats to thick to quick.
    What paints and ration to thinners do you use and how many coats.
    What do you use for a clear coat
    How long between coats.
    Thanks for any advice
    Also
    Anyone in Kent I could potentially meet up with
      • 15650
      Hi Jean
      Welcome to the forum. A very friendly, helpful bunch of modellers.
      The rough finish you are getting may well be due to the paint drying before it hits the model. Perhaps adding a retarder to the mix and slightly lowering the air pressure may help. Certainly you do not want to be putting on a thick coat of paint
        Air pressure, thinning and how close you are spraying to the surface all play a part. Type/brand of paint also will have an effect.
          Jean,
          I use Vallejo paints - Model Air shouldn't need any thinning, but the paint should be " semi-skimmed milk" consistency. I spray generally at about 1.7bar ( 25psi ), using a 0.3mm nozzle airbrush, at about 150-200mm from the model. Smaller nozzles, lower pressure & closer. I allow several hours before any second coat, and overnight before a clear coat ( before panel lining/weathering ). Before spraying a first coat, I suggest you wash the surface with soapy water, and rinse
          • boatman
            • Nov 2018
            • 14451
            • christopher
            • NORFOLK UK
            HI Jean an a welcome from me as well if you can it would be nice if you don't mind to see some pictures as im basically at the same stage as you on this subject
            an what aircraft are you building ? as im a newbie at painting plastic aircraft with weathering an ive got two big kits to build an paint so a bit nervous on that
            but im gonna practice on an old kit when I start . But for some reason in me I keep putting it off thinking i'll learn more before I start
            But good luck on your build as i'll be following your thread
              Jean,
              Cannot add anything to the good advice above, except welcome to the site.
              Mike
                • 18264
                All good advice the only thing I would add is that it's most likely cause is the paint drying befor landing. If you are happy with the mix (paint needle and pressure, just try moving closer to the surface.
                  Hi Jean, a too high air pressure may also result in paint drying before it reaches the surface of your model, but I don't have proper experience with Model Air. I spray Tamiya at 0.8 to 1.0 Bar, but don't know how this works with Model Air.
                  DIRK
