Getting rid of splatter,
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    Evening, spraying the Marder and out of the blue a small splat of paint, ball!!!
    Was going to use very fine sanding to tone it down. Is there another way
    A touch late now, but for future reference:
    If you are quick and get it while the splat is still wet, a brush dampened in the appropriate thinner for your paint and dabbed carefully on the splat will wick the excess paint away. Follow with a light coat over the area and it should be all but invisible.
    Now that it's dried I think sanding is your only option.
    • BattleshipBob
      • 6792
      • Bob
      • Cardiff
      Good one for the future, thanks!
      Bob
      • spanner570
        • 15391
        Bob, sling the A.B. and use brushes.... :tongue-out3:
        • BattleshipBob
          • 6792
          • Bob
          • Cardiff
          Never lol been trying brushing with lots of swearing
            As Andy has said when airbrushing I use a finger to spread .
            After airbrushing just a bit of TLC.
            Depending how high it is. If high just a morton to slice closer to the paint film.
            Lower. Then just a slight sandpaper with a skinny stick. Then in both cases a
            wet & dry paper 1200 with loads of water & it will come down neatly.
            If not perfect & you have gone to far just a little blast with the airbrush will do the trick.
            Just a thought though. With Vallejo not so easy wait at least a day to cure & very gently
            or it will tear. Tamiya types dry in the hour.
            • BattleshipBob
              • 6792
              • Bob
              • Cardiff
              Evening Laurie
              Much appreciated, its been drying since early today so should be ok to sort out
              Bob
              • JR
                • May 2015
                • 18273
                Fire ! Say no more :thumb2:
                  I have used a fibre-glass pen for this - but very gently! I don't like using these, as I get a reaction to the dust - but sometimes you have to!
                    Helps on the reaction side to used a bit of water. Also helps with smoothness.
