Airbrush Lube
  • Bortig the Viking
    • Mar 2019
    • 780
    Airbrush Lube
    I'm looking for advice, now getting into airbrushing I sometimes find even after a good clean the trigger sometimes gets sticky. Would lube help or does anyone have any other suggestions.
    • 15669
    Hi Mark
    I use THIS A smear along the needle and a drop in the trigger and on the threads seems to work fine. Some people use WD40 or Vaseline but I use the proper stuff,
    • Bortig the Viking
      • Mar 2019
      • 780
      Thanks for your reply funnily enough I was looking at getting some with my next order.
      • SimonT
        • 2824
        I use the same stuff as Jim - you only need to use a tiny amount so a tube will last for years
        • Bortig the Viking
          • Mar 2019
          • 780
          Thanks again.
          • BattleshipBob
            • 6792
            • Bob
            • Cardiff
            I also use it, very small blob on a bit of kitchen roll and draw the needle through the blob.
            • Bortig the Viking
              • Mar 2019
              • 780
              It rhymes, blob Bob the stug, lol.
              • Bortig the Viking
                • Mar 2019
                • 780
                On a more serious note, I was looking the other day at some photos I have, very few unfortunately, of the Stug in my grandfather's division during the war, he like many other didn't survive. It's quite a piece of tank history.
                • JR
                  • May 2015
                  • 18273
                  I'm sure every one would be interested in seeing them, If you wouldn't mind sharing them .
                  Like Jim ,Bob and Simon I use the lube, so much better after it is applied. Think the tube will last for some time as you only need a smear.
                  • Bortig the Viking
                    • Mar 2019
                    • 780
                    Thanks for your input, some pictures might not be to everybody's taste, he was in the 5th SS Panzer Division Wiking.
