Following Andy's discussion on his thread about having trouble using Vallejo I had a search on U Tube
Armed with this I set to this morning to do some test of my own.
I used H&S ULTRA WITH A .4 NEEDLE
and the INFINITY WITH A .15
Paints were .
and
First thing was to clean each both AB's fully so no traces of old paint. Using a AS-186 Compresser set at 20 psi.
The magic ingredient and NO thinners .
Before the test I took a sheet of plastic card, washed it in washing up liquid and rinsed it in clean water and dried.
The tests began, first off Vallejo Model Air
I mixed approx 50 /50, and loaded up the Ultra with the .4 needle.
Ten changed to the .15 needle
No clogging at any time ! That should have read .15
Now the test for the Vallejo Model Colour, this one I thought would be the one to really test as its mainly used for brush work.
Starting with the .4 Ultra.
Then some lines. still .4
Finally the 1.5 needle in the INFINITY.
Again should have read .15
My thoughts were maybe I added slightly more more flow improver than I might have needed, next time I shall use 40 /60 .
The main thing is at no point did the tip dry out, or stop spraying, I even left the gun in between moving the card around and changing to the smaller tipped AB.
Normally I would use no more than a couple of drop of the improver per 10 drops of paint, and then use 5 to 6 drops of thinners, and it still might stop and gum up.
I would appreciate any of you guys having a go with out the thinners just the improver and see what results you get.
Certainly something I will do in future with a little play with the amounts. Hope other Vallejo users find it helpful .
John.
Paints were .
and
John.
