IWATA Eclipse HP-CS or Harder & Steenbeck Evolution CR plus Two in One
  • Komedy
    • Jan 2020
    • 307
    Hi all. I'm new here and came across the forum after having placed an order from the shop.
    I'm getting back to scale modelling after perhaps 15 years away and no doubt will have many questions.
    I have a choice between the two airbrushes in the title. The Iwata with a 0.35mm nozzle or the H&S with the 0.2mm / 0.4mm combo.
    The Iwata is £40 cheaper and I will be mainly painting 1:72 & 1:48 scale aircraft with he odd 1:35 tank for good measure .
    Paint wise it will be Tamiya and Vallejo acrylic with some Humbrol enamel.
    As it's been years I'm classing myself as a novice again so which of the two would be the better options for me, would the Iwata meet my needs as it is a few quid cheaper, but concerned it may limit me when I get some practice in.
    Thanks in Advance
    Warren
  • Bortig the Viking
    • Mar 2019
    • 780
    Hi, for me it would have to be the H & S have that exact airbrush, haven't tried the Iwata though. I like the H & S because it's easy to strip and clean, has a proven track record and mine is simply brilliant to use no issues what's so ever. Another point is with the H & S you can remove the cup where as with the Iwata its fixed, helps with cleaning. Others might give you more information, hope this helps.
    • Mr Bowcat
      SMF OG
      • Dec 2016
      • 4600
      • Bob
      • London
      I asked a similar question a couple of years ago and ended up with the H&S 2 in 1. From memory the H&S is easier to strip and clean than the Iwata, and it's always handy having the extra needle. Saying that I rarely use the .2 as the .4 is good for most things.
      Si vis pacem, para bellum.
        Hi Warren,
        If I had a pound for every time that I read that someone is returning to midel building after many years of absence, then I would be a rich man.
        Anyway welcome back. To answer your question for me the H&S I now have three of them and use each for different things.
        I've never had any issues with any of them. They are a quality product in every way. Should you need them spares are readily available and don't cost the earth. Further, they have to be one of the easiest airbrushes to strip and clean with no tools required.
        Enjoy your modelling cheers Alan
          • 15692
          Hi Warren
          I have the H&S 2in1 and an Iwata with a 0.3 needle. As has already been mentioned the H&S is much easier to clean. That said both airbrushes perform really well - my skill is the limiting factor. Either would suit you and I very much doubt either would limit what you want to do.
          • BattleshipBob
            • 6792
            • Bob
            • Cardiff
            Never used a H an S but have 2 Iwatas, i personally find them easy to use, strip and clean
            • Komedy
              • Jan 2020
              • 307
              thanks for all the responses so far. This just arrived today as I ordered it the other day as there was few pounds reduction.
              Hopefully will be enough to get me going.
              • Komedy
                • Jan 2020
                • 307
                Originally posted by Awins
                Hi Warren,
                My wife got me an Airfix kit as a stocking filler for Xrimbo and off we go
                  • 15692
                  Hi Warren
                  That compressor looks like the one loads of us have. It is made in quite a few slight variations. The main thing is it has a tank and is fairly quiet.
                  Have fun.
                  • JR
                    • May 2015
                    • 18273
                    Hi Warren, welcome to the forum, I'm like Jim have that compressor in slightly different format but brill.
                    Use H&S Ultra , and the Evolution with that same size needle as you quoted. Both simple to strip down an unaffected by cleaning fluids, not the case in some cheaper Chinese copies.
                      You may be starting to see a theme here, but I'm a H&S owner too.
                      I'd definitely class myself as an Iwata fan boy as I've invested thousands in their sprayguns for my day job, but the ease of stripping & cleaning, plus the interchangeability of parts between models is what drew me to H&S. And if you have as much bad luck with Vallejo as I've had you'll be stripping it regularly!
                      • stillp
                        • 8093
                        • Pete
                        • Rugby
                        Another H & S user here! I'm opposite to Bob (Bowcat) though, I use the 0.2mm nozzle all the time. With the 0.4 I put too much paint on.
                        • AlanG
                          • 6296
                          I have an Iwata CR Revolution (0.4mm and a 0.2mm conversion) and if i'm being totally honest, i wish i'd saved up a little more for the H&S. Whilst the Iwata sprays everything my skills allow, the cleaning of it is a pain.
                          • SimonT
                            • 2824
                            I bought an H&S CR 2in1 - don’t like it! I know lot of people do though
                            Now use Iwata Neo TR for general base coats, varnish etc
                            A £10 Iwata clone off ebay for basing glue such as Precision Ice and Snow
                            A MIG Air Viper and an Iwata TR0 both in 0.2 for the detail stuff
                            • stillp
                              • 8093
                              • Pete
                              • Rugby
                              I'll give you a tenner for your unwanted H & S Simon! You can buy another Iwata clone then...
